| | #1 |
| Pebble Pounder Join Date: Dec 2007 Location: roanoke,tx
| I searched and didn't find what I was looking for.what do you guys use besides jb weld to lock the diffs?I see axial and wk diffs are the same.and they use a 1 piece design.the ones from rc guy are 2 piece.think there are any differences?thanks alot. |
| Sponsored Links | |
| | #2 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| I used Axial lockers and they are about $20. You can also get "RCguy" lockers, I think they are $5 or so cheaper. Only reason I got the Axials was b/c I made a big order at tower and they didn't have RCguy stuff. |
| | #3 |
| Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
| I like the RC Guy lockers. |
| | #4 |
| Crawling is a fad... ![]() Join Date: Aug 2007 Location: Toronto, Canada
| Yep, insert 2 of the rcguy lockers into one cup and fasten it down. No mess to worry about. http://www.tcscrawlers.com/RcGuy-HPI...g-p-16309.html Axial / WK parts might have some interchangeble parts, but from what I saw of the Axial Axles they are completely different. I could be mistaken, but I think the Axial's are a bit wider also? |
| | #5 |
| Quarry Creeper Join Date: Mar 2007 Location: Beaver Dam
| I carefully loaded the carrier with solder...the gears are fused till hell freezes over and I spent like 2 bucks. Oh and my diffs weigh a ton! (Low weight rocks!) |
| | #6 |
| Newbie Join Date: Oct 2007 Location: Canada-Quebec
| | #7 |
| Rock Stacker Join Date: Jul 2007 Location: Albuquerque
| I used a two part metal epoxy. It sets up in about 5 minutes, and only cost ~2 dollars and some change. I got it at Home Depot in the paint department. It is the same stuff that HPI recommends in their stage 1 build mods. |
| | #8 |
| Quarry Creeper Join Date: Oct 2007 Location: Ohio
| The best way is to get lockers. I have RCguy lockers and would recomend them. |
| | #9 |
| Pebble Pounder Join Date: Jul 2007 Location: USA
| I am assuming it wasn't melted solder? If it was, how did you keep from melting the carrier? Good idea though. |
| | #10 | |
| Pebble Pounder Join Date: Jul 2007 Location: Quebec City
The cheapest way is JB weld. I don't care spending 10$ more for the right thing... Since every mod has to get modded again and again, I would not like to go inside the diff for any good or bad reason once it has been JB welded... | |
| Thread Tools | |
| Display Modes | |
