Thread: stock gearing?
Old 12-19-2007, 11:38 AM   #1
Default stock gearing?
what is the stock gearing?
trying to decide on gearing for a inthe middle speed between crawling and bashing for a trail truck not comp.
bigblazerboy is offline   Reply With Quote
Old 12-19-2007, 12:19 PM   #2
stock gearing is 21 / 90. im using 21 / 96 with a 65 turn lathe and find it great all around.
mark2003 is offline   Reply With Quote
Old 12-19-2007, 12:28 PM   #3
get a 35 turn from R2J. And for gears run 21/93
Shaun is offline   Reply With Quote
Old 12-19-2007, 12:42 PM   #4
i was thinking about a 35t but my lhs's lowest is 45 or 55.
would a 15/90 be good with stick motor for now?
Old 12-19-2007, 12:43 PM   #5
o yeah, were do youall get gears, and are they the hpi ones or different . i want to try to get most of it in store.
Old 12-19-2007, 12:57 PM   #6
you wont be able to get your gear mesh tight enough using the 15 tooth pinion with a 90 tooth spur, your motor will hit the tranny case. thats why i went with the 96 tooth hpi spur. i also bought a 15 and 16 tooth pinnion but found i like running my 21 tooth with the 96
Old 12-19-2007, 01:42 PM   #7
then what woulod be a in the middle gear set and motor?
Old 12-19-2007, 02:39 PM   #8
i wouldnt say its in the middle but just going to a 96 tooth spur with the stock motor and pinion made a noticeable difference in the bottom power and diddnt make the speed suffer verry much. but i still put a 65t integy motor in mine and run 96/21 and think it works verry well allaround.
Old 12-19-2007, 02:45 PM   #9
ok cool. im stilll waiting for my battery to finish chargeing and i will see if i lke the stock gearing.
Old 12-19-2007, 03:10 PM   #10
I was talking about the 35T warrior. I'll be runnign one in my 2.2 scaler, should make a good fit.
