Thread: new wheely king, have question
Old 12-21-2007, 09:55 AM   #1
Default new wheely king, have question
got my first crawler today for $200
its a wheely king extened to 13.5" center to center, custom 4 link, locked diffs, geared and 65 turn intergy motor, 2.2 swamp dogs on bead locks, battery and sefvo on front axle, and t-maxx shocks......one thing i oticed is it dosnt articulate as good as my friends stock shocked one, i think the shocks have the wrong oil in there because the shocks can go up about anuther 1/2" but they stop because there no weigh added....should i just dump all the oil out and run it oilless in the shocks ?
pictures are here http://www.rcuniverse.com/forum/m_6786715/tm.htm
ridinbikes247 is offline   Reply With Quote
Old 12-21-2007, 10:18 AM   #2
T-Maxx shocks are 100 mm while stock WK shocks are 120 mm, can it be the reason why you are loosing some articulation ?
Or is it just that the shocks rod does'nt compress completely into the shock body ?
Filibuster is offline   Reply With Quote
Old 12-21-2007, 10:53 AM   #3
sounds like the springs are to stiff. try taking them out and trying it with out springs. oil should not stop them from moving it just to slow the movement down and help the rebound etc. of the shock.
execelon is offline   Reply With Quote
Old 12-21-2007, 10:55 AM   #4
Or is it just that the shocks rod does'nt compress completely into the shock body ?..thats what it is..the shock shaft is still sticking out like a nuther 1/2"...if i push down on the truck it will go down..its like the truck dosnt wiegh enough or the shock oil is to thick or somthing
Old 12-21-2007, 11:03 AM   #5
You might just have too much oil in your shocks bodies.
Remove the shock, take the spring out and push on the shaft so it goes inside the body. The shaft should go in there easily without returning extended (or very little rebound).
Old 12-21-2007, 11:36 AM   #6
SCALE PERFORMANCE PARTS
Locked Up's Avatar
This sounds like the issue to me. Maybe you should trim your springs a little
Locked Up is offline   Reply With Quote
Old 12-22-2007, 09:51 PM   #7
Take them apart and check for fuel tubing or internal springs. They may be limited on purpose
fatbastard is offline   Reply With Quote
Old 12-22-2007, 10:51 PM   #8
I really don't see how this can stop a shock from moving.
Shaun is offline   Reply With Quote
Old 12-23-2007, 04:47 PM   #9
i dont really understand it either but it is true, i see it all the time.
for some reason if u over fill them they will act like a progressive spring making it harder as the shock gets more compressed.
savagecamaro is offline   Reply With Quote
