| | #1 |
| Newbie Join Date: Dec 2007 Location: bethlehem
| this is my first wk build... so far i: locked the diffs with CA battery in front custom servo mount 15/96 gears jr 126mg axial rockstars(black chrome) w/ moab 2.2 w/ no foam savage shocks custom painted dam ram body in progess (go chevy) no links as of now (parts r on the way) everything else is stock ![]() |
| Sponsored Links | |
| | #2 |
| i just realized looking at my axle shot that i had put the rears on backwards from the way i wanted to but i was looking at pics of others nd they had there tires all diff ways which way is best? oh and did ne1 notice with the 96t spur there is a rubbing sound with the gear cover on, but i couldn't see where it was rubbing... Last edited by savagecamaro; 12-23-2007 at 05:51 PM. |
| | #3 |
| once i get back from work today i will have the tubing for my links so they should be done by tonight |
| | #4 |
| | #5 |
| Pebble Pounder Join Date: Nov 2007 Location: Canada
| I ran the same wheel setup without drilling air holes in the rims with no foams. I didn't enjoy it. Too bouncy on the rocks. I drilled 2 1/8" holes in each rim, and did heavy star cutting and narrowed foams. Much better and great traction. I also noticed that in snow crawling... flipping your tires around(side for side) to reverse the tread pattern makes the tires dig like crazy abd works nice. -Matt |
| | #6 |
| i didnt drill ho,es in the rims cuase i didnt have a drill at work ..u can see that i cut 2 holes in each tire to let air escape, the on is on the left tire on the front axle pic.. too bad all the snow just melted or i could try the tires backwards. |
| Thread Tools | |
| Display Modes | |
