| | #1 |
| Rock Stacker Join Date: Nov 2007 Location: metairie
| 1.what ESC should i get i have a 55t lathe motor coming in soon wit 13/96 gearing i have some beadlocks with mud slingers the battery is up front im getting new shocks new body and also im gettin rear wheel stearing but i jus dont know what ESC to get i dont want to get a novak rooster 2 much for me im only 16 so someone please help me tell me which one to get, a good one that is pretty cheap but not to cheap thanxx |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| Anything other than the stock ESC is better. I've seen a number of guys running a DuraTrax esc that cost them like $30. |
| | #3 |
| Quarry Creeper Join Date: Oct 2007 Location: Ohio
| I have a duratrax intellespeed. It works good. I would get one of those if your on a budget. Depending on which one you get there from $25-$60. |
| | #4 |
| RCC Addict Join Date: Feb 2005 Location: in my house
| | #5 | |
| Quote: i might get this one thanxzz but is there a certain kinda of battery that i willneed or motor i have stock battery but i am goingto get a few good ones wat are a few good batteries i could get to use with this one | |
| | #6 |
| http://cgi.ebay.com/New-Novak-Rooste...QQcmdZViewItem neone have this imight just go ahead and pay the money and getthis i justneed to no if ne1 has this andhow well does it work |
| | #7 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| If you are gonna cough of the dough for a nice esc, I'd get a Mamba Max. You can run any motor & any battery with it. It's totally programable and doesn't suffer form the "glitch" issues the Novak has with cheaper radios. It's what I run and I love it. |
| | #8 | |
what bout a cheaper one mayb about $70-80 so dont get the Novak what sholdi get then i have no clue | |
| | #9 |
| The esc you posted was $100 after shipping the Mamba isn't much more than that here.... http://holmeshobbies.com/product.php...1&cat=0&page=1 You could also look into one of the cheaper brushless combos he has.... http://holmeshobbies.com/home.php?cat=4 |
| | #10 |
| i dont want an expensive one i would like one that can run my55t lathe motor from integy and a relly good battery nd one that has ABS so when imon ahilli can stop or wat eva |
| | #11 | |
It's really hard to read your posts when you don't use full words. Novak has a drag brake that is not adjustable and they are working on the programming issue. There is an entire thread about it. It might be a good idea to wait on that one. Castle Creatons (makers of Mamba Max) are supposed to be bringing out a "Sidewinder" ESC, which will be just like the Mamba Max, but cheaper. I believe the difference between the two will be that the sidewinder will not be able to handle as much juice, but with the motors we all run, it's not an issue. Other than Novak Crawler & the Mamba Mmax, I'm not sure who has a drag brake ESC currently for sale. The Moped & TR2 are both common but neither of them have drag brakes if I recall correctly. | |
| | #12 |
| so what ESCshould i get for the 55t lathe motor what are your suggestions im new to rock crawling and i dont really no what is good and what is not good |
| | #13 |
| Quarry Creeper Join Date: Dec 2006 Location: dot com
| You need to look at specs. I used Novak XRS (45$) for a while ,but the bec sucks. Tekin rebel 2 has way better bec and more input power (75$), Rooster crawler is the only one designed for crawlers(90$). Mamba Max is the best period(135). If you dont have the cash, you will have to figure out what has the most important features to you for your money. Drag brake is nice, but not all important unless you compete. Find what has the best bec and input voltage for your buck and start there. |
| | #14 |
| Don't forget you can get a MM for under $135 if you shop ... And for any of them that have crap BECs, you can run a seperate BEC like the Castle Creations unit ($20). Also, you do not HAVE to get a new ESC just for the 55t motor. You can run it for a while (even with a 7-cell) to see if Novak sorts out their issues or what the Sidewinder will cost. |
| | #15 |
| Newbie Join Date: May 2006 Location: WOODBRIDGE
| i have 2 of the dynamite tazer 15t they are realy good speed controlers and have reverse also...they are 27.99 at the hobby shop |
| Thread Tools | |
| Display Modes | |
