Thread: what way is there for me to gain more ground clearance with this setup?
Old 12-24-2007, 03:56 PM   #1
Default what way is there for me to gain more ground clearance with this setup?
Alright, This is how my WK sits as of now. I have bent the lower links in hopes to get more ground clearance to no avail. What I am wondering is, how can I increase my center ground clearance without buying a new chassis?
This is a better picture of how the links are setup. I now have the lower links mounted on the top hole in the stays with the shocks.
lsone is offline   Reply With Quote
Old 12-24-2007, 03:58 PM   #2
i would say get some bigger shocks than stock ones
try these
http://cgi.ebay.com/NEW-HPI-Shock-Se...sid=p1638.m118
wheely king 69 is offline   Reply With Quote
Old 12-24-2007, 04:23 PM   #3
hitman46mod's Avatar
You can relocate the shock farther down the chassis. Like this. It will net you about 3/4" more Ground clearance.
hitman46mod is offline   Reply With Quote
Old 12-24-2007, 05:41 PM   #4
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I think your only option would be to do something that will also raise your COG. That's the big killer with these chassis.
I'm surprised you haven't relocated the shocks yet. That was one of the first things I had to do to stop them from binding.
The stock shocks suck anyway so I'd get these:
http://www.jpcustomrcs.atomicshops.c...79/4462034.htm
Only 3mm longer but if you relocate everything they will work great.
I shortened my springs a bit after relocating them so it's almost like a droop setup:
http://www.patricksnorton.com/WK/tec...I/IMG_2753.JPG
http://www.patricksnorton.com/WK/tec...I/IMG_2748.JPG
Locked Up is offline   Reply With Quote
Old 12-24-2007, 06:11 PM   #5
haha, I cut off my chassis from the shock towers to the end of the chassis so those holes are non existant now. darn.
Old 12-25-2007, 07:00 AM   #6
Try stiffer springs.
LST022752 is offline   Reply With Quote
Old 12-25-2007, 08:31 AM   #7
crawl rookie's Avatar
Use/make a better chassis yourself ,
the stock king chassis is pretty worthless if you want more ground clearance
And it isn't that hard to make one, just do some recearch
crawl rookie is offline   Reply With Quote
Old 12-25-2007, 04:29 PM   #8
lower the shocks or get bigger tires
ON THE ROCKS is offline   Reply With Quote
Old 12-25-2007, 10:54 PM   #9
JIA's Dad's Avatar
You can buy wheels that narrow the axle width. This will give you better axle clearance in some instances over the rocks.
JIA's Dad is offline   Reply With Quote
Old 12-26-2007, 12:48 AM   #10
i moved my tranny up and cut the bottom of my chassis. it's solid and gives me alot me clearance
joehein is offline   Reply With Quote
Old 12-26-2007, 01:52 AM   #11
MWRCA'er
Mnster's Avatar
Easy way?
Buy some longer rod ends for the shocks
Mnster is offline   Reply With Quote
Old 12-26-2007, 10:39 PM   #12
cut the bottom of chassis off,theres pics somewhere,my mate did the same as mine but only moveed the motor/tran's up alittle bit not as much as mine
kiwi trasher is offline   Reply With Quote
Old 12-27-2007, 01:10 AM   #13
i did a thread on it, ill see if i can dig it up.
