Thread: batt. mounting?
Old 01-02-2008, 01:44 PM   #1
Default batt. mounting?
Well, i have just finished my wk, and it looks rather good. (pics will come up later). The one thing that completly left my mind during the whole build was, where to put the battery. Any ideas? Its a regular 6 cell pack, and i have trouble finding room. thanks!
gearmonkey23 is offline   Reply With Quote
Old 01-02-2008, 01:47 PM   #2
mount it on the front links like mine. it keeps weight up front where you need it.
juststartin is offline   Reply With Quote
Old 01-02-2008, 05:58 PM   #3
I made a saddle pack and mounted my pack on the axle.
http://i85.photobucket.com/albums/k7...t/P1010010.jpg
http://i85.photobucket.com/albums/k7...t/P1010011.jpg
YZF Desert is offline   Reply With Quote
Old 01-02-2008, 06:00 PM   #4
yzf you make that servo mount????
ScGRaceR is offline   Reply With Quote
Old 01-02-2008, 06:31 PM   #5
yea, I made it from the templetes in the WK templates sticky, pretty much used the basic tools, dremel, grinder, drill press, files.
Old 01-02-2008, 07:05 PM   #6
Heres how i mounted mine it helps pull the fornt end over stuff and if u need more weight in the rear you can slide the another one in.
http://www.kodakgallery.com/Slidesho...e&conn_speed=1
Adam
adam is offline   Reply With Quote
