Thread: WK BMVII crawlers
Old 01-07-2008, 10:33 AM   #1
Default WK BMVII crawlers
here is a pic of Ali's (my wife) and my crawlers. both are WK units with the BMVII chassis. The colors are exactly opposite each other. Her's is the silver to Blue fade with the orange accents and mine is the silver to orange fade with the blue accents.
The orange one:
WK front axle with alum hubs (TCS), 303 stainless axles (RC4WD) 4130 cut gears.
WK rear axle with 303 stainless and straight axle adapters (RC4WD)
BMVII chassis
R2D trans (TCS)
towerpro servos 945's (rockwerks)
spektrum on JR r-1
mamba max esc (JRH)
axxiom 55t
adjustable BEC (JRH)
Losi rock claws (TSC)
custom laminated foams (rockwerks)
Billetworks custom beadlocks
The Blue one:
WK front axle stock
WK rear axle with straight axle adapters (RC4WD)
BMVII chassis
WK trans on custom laydown brackets
spektrum on JR r-1
mamba max esc (JRH)
integy 55t
Billetworks assassin beadlocks
rockwerks is offline   Reply With Quote
Old 01-07-2008, 10:42 AM   #2
is alot of diference between the axiom 55t and the integy 55t??
btw nice trucks!!
andres-tavares is offline   Reply With Quote
Old 01-07-2008, 10:46 AM   #3
You and them wierd body's, haha.
How are all the axle upgrades holding up? Can I get a width of the track with those new wheels?
Cslax06 is offline   Reply With Quote
Old 01-07-2008, 11:06 AM   #4
btw nice trucks!!
yes the ax is much smoother and a bit more wheel speed
with the stock screws in the RC4WD straight axle adapters on the rear the screws actually bottom out on the axle shafts, you need to use a washer or cut down the screws, or the shafts will scores and cause a break. Other than that Im happy with everything. the track on both is right at 10" to outside of rock claws and 9 3/4" to the outside of the rims
Old 01-07-2008, 12:20 PM   #5
Man RC4WD...
Well that 10'' is good to hear. I think Im going to go ahead and buy some. Along with the nre RC4WD Rock Cruiser tires.
Old 01-07-2008, 12:54 PM   #6
Question
May I have some topless pic?
PROTOTYPE is offline   Reply With Quote
Old 01-07-2008, 01:41 PM   #7
In a couple of days jsut dropped the camera into some tranny fluid....have a replacement camera on the way
Old 01-07-2008, 06:34 PM   #8
Id also like a front on look with those wheels. I want to see how much of the C is covered.
Old 01-15-2008, 05:24 PM   #9
Any pics yet? I'm interested in this chassis
Twist is offline   Reply With Quote
Old 01-15-2008, 08:32 PM   #10
here ya go, the c's are covered to the edge or center of the mounting screw depending on the hex sized used
Old 01-16-2008, 12:03 PM   #11
That look's interesting.I have been away from the w/k forum's for a while,i've never seen anything like that before.It looks like a couple welding rod's for a chassis,very strange>So how's it work?Do you have good flex?Any problem with torque twist?How do you tune the suspension because i don't see any shock's.Sorry for all the questions but that chassis really make's me go hmmmm,tell me about it ,what is some of the thing's you don't like about it?
ridgewalker is offline   Reply With Quote
Old 01-16-2008, 05:53 PM   #12
actually its 1/8" spring steel
So how's it work?
Finished 35th this year at Nationals with it and should have done better but had the wheelbase adjusted too short, had it down to about 12" instead of 12.5"
about 50* as you can see in the picture, more than enough. Flex is directly related to wheel weight
absolutely none, suspended rigs have that issue not a BMVII
by adjusting the wheel base and adding or subtracting weight in the wheels
I dont like that I cant get more right now LOL and that would be about it.
We are currently working on a BMVIII version that should be available for spring
Old 01-16-2008, 06:03 PM   #13
OFFROADJERKY.COM
Shoei1's Avatar
Is there a way to buy this kit for a WK. I was thinking of just building one but if i can buy one that would be great.
Shoei1 is offline   Reply With Quote
Old 01-16-2008, 06:09 PM   #14
unfortunately not at this moment. but soon.
Old 01-16-2008, 06:26 PM   #15
OFFROADJERKY.COM
Shoei1's Avatar
Well i guess i will have to put my hands to work. You said you used 1/8 steel rod and where would i find that.
Old 01-16-2008, 06:52 PM   #16
piano wire, hobby shop
Old 01-16-2008, 07:57 PM   #17
rockwerks Thank you for the informitive reply.Is this chassis only for rock crawling or could it be used in other applications?Would it work well in a faster truck?Could it handle rough terain well at high speed (30 mph)?
Old 01-16-2008, 07:59 PM   #18
LIKES2CRAWL's Avatar
Yea don't use steel rod or it will just bend and stay that way as piano wire flexes and dosent hold a bend unless realy tweeked.
LIKES2CRAWL is offline   Reply With Quote
Old 01-16-2008, 08:11 PM   #19
The bta steering looks great.
nigels_world is offline   Reply With Quote
Old 01-16-2008, 08:15 PM   #20
its designed to be a crawler, shocks are needed for control at high speeds. if you hit something this chassis would fold up
thanks! WK = easy BTA steering.
