Thread: Here's my truck!
Old 01-09-2008, 02:44 PM   #1
Default moved the servo to the front axle
these are some pics of my wk. I have taken the wk steering links off and made my own out of all thread and alum tubing since these pics. I am still adding my goal is to win a comp with this truck and once I have done that then I will make my own from scratch!! hope you like!
inside the truck
65t lathe integy motor
118 mm bottom links
100 mm top links
96t spur gear
15t pinion
locked diffs front & rear
straight rear axle adapters
[[/IMG]
IcemanXtc is offline   Reply With Quote
Old 01-09-2008, 02:46 PM   #2
Looks like a good build. what rims are those?
gearmonkey23 is offline   Reply With Quote
Old 01-09-2008, 02:49 PM   #3
Default Rims
axial bedlocks 2.2
tires are proline mashers
Old 01-09-2008, 03:39 PM   #4
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Originally Posted by IcemanXtc View Post
axial bedlocks 2.2
Can you tell me the true diameter of those tires, on those rims? I was looking at them but I think they are a little shorter than moabs ...
Locked Up is offline   Reply With Quote
Old 01-09-2008, 03:54 PM   #5
Default wheel specs
axil rockster
SPECS: Width: 1.4" (36mm)
Beadlock Diameter: 2.2" (55.5mm)
Hex Size: 0.47" (12mm)
pro line mud thrashers
SPECS: Inner bead diameter: 56mm (2.2")
Total outer diameter: 124mm (4.9")
Inner bead width: 50mm (2")
Total outer width: 62mm (2.4")
hope this helps!!!!
Old 01-09-2008, 05:58 PM   #6
loooks good how do you like the 65t in that thing
ScGRaceR is offline   Reply With Quote
Old 01-09-2008, 06:06 PM   #7
Locked Up's Avatar
axil rockster
hope this helps!!!!
I'm wondering what they really are mounted on those specific rims because my Moabs are supposed to be 4.95" but they are a hair shorter mounted on my rocksters.
Towerhobbies has those listed as 4.9" ... but the M3 version as 4.72 ... which is why I asked.
Old 01-09-2008, 10:27 PM   #8
Default 65t motor
the motor works great i have the stock esc on for now and that thing stinks but when i installed the new motor that helped alot with the braking. i cant wait till i get the rooster this thing will be able to hang on a verticle slope.
Old 01-09-2008, 10:30 PM   #9
im not sure i understand.
Old 01-10-2008, 08:36 AM   #10
What he wants to know is the actual size of those tires on those wheels. Just like with real truck tires, most tires won't measure the same when mounted on wheels as they do in the manufactors specs. If you put those tires on really narrow wheels, they would be bigger diameter than if you mount them on really wide wheels, and they probably wouldn't match the manufactors specs in either case.
asfasasu3 is offline   Reply With Quote
Old 01-10-2008, 02:22 PM   #11
Sorry first truck and still new to this. I manually measured them and the width of the tires is a little under 2 1/4 inches. measuring from the rim to the top of the tire is a little under 1 1/4 inches.
if this isnt right just explain to me how it needs to be done and I will do that.
Again sorry for the Ignorance but I bought this truck stock out of the box two weeks ago and this is the first time I have ever had a r/c!
