Go Back   RCCrawler Forums > Regional > West > Idaho
Thread: spektrum DX3R Help
Old 02-06-2012, 07:11 PM   #1
Default spektrum DX3R Help
Hay guys, im sure that someone here local would be willing to help me out with understanding alll the set-up with a Spektrum DX3R.
I have the manual, but it is very vague & i cant seem to get throttle response to work correctlu. (it literly took me 3 days just to get forward & reverse figured out.)
You would think that being in the hobby since the 80s that I know this, but I dont. I never had realy nice radios. Just cheep futoba & airtronics.
So if you could help walk me through what all the curvs (ie: throttle, braking, etc) mean/do, Id realy appricate it. cuz, Im a bit lost! (over the phone or in person would be the best. Im a slow typer.)
airdreams1 is offline   Reply With Quote
Old 02-07-2012, 01:28 AM   #2
Default Re: spektrum DX3R Help
Ive got a dx3r.but I only know where the steering gas and brakes are..in all seriousness ive no idea.
SH!ITBIRD91 is offline   Reply With Quote
Old 02-07-2012, 02:16 AM   #3
Its strange as hell to me. Ive never had or heard of any radio that doesnt alow the rig to move forward or reverse till you figure out all the settings!
Im hopeing to get it figured out before the scale comp on saturday otherwise Ill have to change the reciever out & use my old radio.
Old 02-07-2012, 09:16 AM   #4
I am sure we can get you going at the comp this weekend. but it sounds
like you didnt bind the reciever and trans. if the car wont go at all.
Does the steering servo work?
JUSTCUZ is offline   Reply With Quote
Old 02-07-2012, 09:44 AM   #5
I bound it & the servo workes just finf right from the get go....... It had no throttle at all till I tweeked the "throttle" travle, sub trim & exponential... (esc is a sidewinder) But now the throtle is way to glitchy & sensitive. kindof all or nothing. This damn radio is complicated.
Old 02-07-2012, 10:17 AM   #6
Sounds like you need to calibrate the radio to the ESC.
Turn on the radio
Put all throttle epa's to 100 and center the trim
Pull full throttle and hold
Turn on the truck with the switch, plug in the battery, or what ever it takes to make the ESC and receiver come to life
The ESC will chime when it finds the forward setting from the radio
Then push full reverse
ESC will chime again when it finds reverse
Let go of the throttle
ESC will chime again when it finds neutral
Dont do anything
ESC will chime again, and should be ready to go
KBrog is offline   Reply With Quote
spektrum DX3R Help - Similar Threads
spektrum dx3r yfz350 Electronics 3 10-27-2010 09:55 AM
Spektrum DX3R help daymo Electronics 0 05-07-2010 02:45 PM
New Spektrum DX3R! BGGruff Electronics 21 01-22-2008 06:24 AM
HTML code is Off
