best way to join a rwvo drive shaft to the output shaft on the axle just like the title said. i have drilled the pinion, but it not straight so i get a lot of wobble so i have a new set but i need to find a better way to join up my redo drive shafts. i saw some were a custom aluminum one made by Mike?? i think. but i can't find them any where. any help would be great thanks |
Re: best way to join a rwvo drive shaft to the output shaft on the axle "Cordwood" knows all about this........ I'm sure he'll Chime in here Regards Rick |
Re: best way to join a rwvo drive shaft to the output shaft on the axle rc-monster.com has an aluminum coupler for revo shafts and 1/8 scale different. I plan to use these. |
Re: best way to join a rwvo drive shaft to the output shaft on the axle v8 4x4 are you making steering linkage to work on the full size TF axles? i'm using you servo mount(which are super cool) but the servo horn hits the main link, so right now i have the horn pointing up. was wondering if you made a bent one to fit around it thanks thanks vwmopar. those look perfect just going to wait to see if any one else chimes in |
Re: best way to join a rwvo drive shaft to the output shaft on the axle Quote:
Mount the servo on a set of the angled servo mounts or put some shims under it. Other option is to rotate servo mount back but that seems to set the shark fin off.. just a few ideas hope that helped |
Re: best way to join a rwvo drive shaft to the output shaft on the axle I forgot to say, when I drilled mine the were way off and all I had to do is spin it and but the pin in from the other way. it got them to run more true and if you need to drill the hole a little deeper in the end that slides onto the pinion, my first one wasnt sliding on for enough. I wont lie, I found it all a pain in the @ss also but just work with it and see what you can do. I thought mine were done but now the work great. |
Step by step instructions with Pic's Product_Reviews New reviews pages added to SuperShafty.com Thank you "Cordwood" |
Re: best way to join a rwvo drive shaft to the output shaft on the axle well done |
Re: best way to join a rwvo drive shaft to the output shaft on the axle Whoa, how'd I miss this thread. TRAV, i responded to your PM earlier today. It's an easy mod and I'm pretty sure the couplers are in stock. Thanks MJ. |
Re: best way to join a rwvo drive shaft to the output shaft on the axle thanks for getting back to me so soon. i just got 2 on their way looking forward to getting them. just to clarify i will need to drill and tap new set screw hole. on the other side closer to the end. is that right. could a guy cut them down so they slide on further and use the stock hole, or would i have to cut away to much to make it work that way.. thanks |
The problem with cutting it down is you'll lose that lip that hits the inner bearing race. You could tighten it up off the beating and hope it doesn't move or it'll hit the axle case or outer bearing race. Plus you'd be cutting a fair amount off. |
Re: best way to join a rwvo drive shaft to the output shaft on the axle great thanks can't wait to get the warthog up and running soon had it out for the first time today in a year. already broke a dog bone when i put the supershafty 4 link mounts instead of the stock TF ones i put the axle screws into far and they were rubbing on the bone and coursed it to break live and learn |
No real plans for steering linkage because of so many different options :cry: Regards Rick |
