Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Forced Wraith
Old 10-31-2014, 10:11 AM   #61
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Default Re: Forced Wraith
This truck was a collaborative effort between Crawler Innovations & Szczerba Built. It also uses many vendor parts & services from RCCrawler.com.
The CI Forced Wraith rc rock crawler uses Kyosho Twin Force axles front and rear. The axles have many custom made parts in them. They have been narrowed for this project. The front housing is a modified RC4WD aluminum housing. The axles are geared with 4.30's.
The transmission is Axial AX-10 based design, but none of it is Axial LOL. VP trans Case, Crawler Innovations 6mm chromemoly output shafts, RRP gears, BWD Motor Plate, etc. Geared 62/10
This truck as filmed in this video weighs 9 pounds 11 ounces.
Build Thread Link:
http://www.rccrawler.com/forum/kyosh...ed-wraith.html
The tires are 2.2 Pitbull Tire Rockbeast 2's that have been modified (cut n shut) to fit on 2.2/3.0 RC4WD aluminum bead lock rim. The foams are Crawler Innovations Deuce's Wild 2.2 Tall foams that have been modified to fit the 2.2/3.0 rim. It is a single stage foam designed to support heavy weight crawlers and is 100% water proof.
Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations
The Forced Wraith runs on 4S lipo (16 volts), Castle Creations MMP ESC & BEC, Tekin 412 3100KV motor, & Hitec servos.
Nova's Ark is offline   Reply With Quote
Old 11-01-2014, 06:04 PM   #62
Bart bender's Avatar
Nice vid. But that music! GOD!
Bart bender is offline   Reply With Quote
Old 11-02-2014, 07:16 AM   #63
Nova's Ark's Avatar
Thanks,
YouTube has fits with certain music. YouTube seems to prefer instrumentals LOL.
I'm still itching to fix the mega truck :-D
..Uploaded from the lab @ the C.I. Compound...
Old 11-09-2014, 07:14 AM   #64
Moderator Rule Breaker
eric113's Avatar
Quite jealous.
I remember when onespeeder built his twinforce super and used universals. He had 60*-70* turning with rear steer.
eric113 is offline   Reply With Quote
Old 03-10-2015, 06:30 PM   #65
Nova's Ark's Avatar
It's been a while since an update.
This truck was built with a plastic case transmission and a plastic spur gear. With the release of the axial yeti, new upgrades mean new possibilities. The yeti steel spur gear fits the scx slipper assembly:
Thank you to Vanquish Products for the new transmission case.
Old School Crawler Innovations 6mm flat extended front outputs
Old 03-12-2015, 11:13 AM   #66
SuperShafty.com
keep going...
mjderstine is offline   Reply With Quote
Old 07-26-2015, 10:05 AM   #67
Nova's Ark's Avatar
This video is a compilation of video footage from many different locations using RC cars Crawler Innovations has built and used to test and develop CI products. This video features the 1:6 Willys Jeep, the Forced Wraith, Big Blue, a Wrexo, two different 2.2 Pro MOA Rock Crawlers; Top Shelf, the Mini Clod, the 1:5 Savage, and the Mega Truck. All vehicles have build threads on the rccrawler forum. All vehicles have Crawler Innovations foams in one flavor or another.
Old 08-31-2015, 08:12 AM   #68
Nova's Ark's Avatar
This video is a compilation of video footage from many different locations using RC cars Crawler Innovations has built and used to test and develop CI products. This video features the 8x8, the FTOY, 1:6 Willys Jeep, the Forced Wraith, Big Blue, Top Shelf, and the Fun Truck. All vehicles have build threads on the rccrawler forum. All vehicles have Crawler Innovations foams in one flavor or another.
Old 12-16-2015, 06:51 AM   #69
Nova's Ark's Avatar
Update; the Forced Wraith is still going strong. The brute strength of this rig has held up to Gavin and miles of drive time. It's Gavin's class 3 competition rig and he enjoys it. ETXRCC is taking December off from competitions and we are using the down time for maintenance.
Gavin had been asking for a motor and possible gearing change. He wanted more low speed crawlability and was willing to give up a little top speed as well. Out with the old 3500KV set up and in with a Tekin 2400KV Pro4. I went ahead and added a super shafty top shaft with a RRP 56T spur gear assembly with an 11t pinion, both 32pitch.
Old 04-18-2016, 10:21 AM   #70
This rig is just too cool.
Random question, you have any other HPI pinions around that may have a part number? Looking for some way to overdrive the front axle in my build as well.
What Universals did you end up swapping into this?
I wish you could still find those knuckles somewhere, super cool setup.
Wes
WesTX is offline   Reply With Quote
Old 04-18-2016, 08:53 PM   #71
SuperShafty.com
well darn. i recognize that packaging.
too bad you didnt get the new black shaft! because once you go black...
Forced Wraith - Similar Threads
First Forced Upgrade! :( Scurvy Axial Wraith 29 03-22-2012 05:37 PM
Forced Articulation (3P)? Access Electronics 6 10-22-2008 05:08 PM
Forced articulation leagality Kamikaze WRCCA Rules 20 12-06-2006 04:18 PM
Forced Artic Rikpal General Crawlers 13 10-12-2006 04:45 PM
