04-05-2015, 01:01 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Prospect park
| hows this?
I filled my front diff with mostly traxxas 10K oil and added 2 pea sized globs of traxxas 500K diff oil in it also, the ? is this to thick up front? see video of it's action when I turn the wheel by hand quickly. let me know what you think? THANKS |
04-06-2015, 01:19 AM | #2 |
Pebble Pounder Join Date: Jul 2009 Location: Suomi Finland PERKELE !
| Re: hows this?
Do You have full set of spiders in the dif ? 10 K is on the soft side, I don't know how much that 500 K stiffens it up but 40 K would be good starting point ( with full set of gears )
04-06-2015, 06:55 AM | #3 | |
| Re: hows this? Quote:
you can feel it when you just turn the wheel by hand slowly it has a drag to it. what should I do in the rear they say 3000K in the instructions? better thick in the front and loose in thin in the rear? that's what I read. THANKS | |
04-06-2015, 01:55 PM | #4 |
| Re: hows this?
Just got done putting the rear together I used 10K and mixed a lot of 60wt shock oil in it , Now that the truck is together the rear feels just a hair stiffer than stock with only the grease. it spins pretty long after I flip the tire with my hand.... don't know if that's how it looks when using 3000 weight? |
04-06-2015, 03:00 PM | #5 |
| Re: hows this?
Sounds good, 10K should be fine even with out thinning. I don't think 3000 will have any locking effect with big tires. I went from 15000 to 20000 to 40000 before it was to my liking
04-06-2015, 03:56 PM | #6 | |
the rear from what you explained I many have made 3000 to 5000 oil by mixing them up when you turn the rear slowly by hand you can slightly feel pressure. the front when turned slowly by hand you can really feel pressure like a gummy twisting taffiy feeling, don't know if I went to much...but it seems to be working. example if I hold the truck up and turn one front wheel real fast by hand like in my video the chain sprocket starts to turn a little ,,, maybe to thick? Last edited by shenlonco; 04-06-2015 at 03:59 PM. | |
04-06-2015, 06:42 PM | #7 |
Rock Stacker Join Date: Sep 2010 Location: Norway, HOME OF THE VIKINGS
| Re: hows this? |
04-06-2015, 06:53 PM | #8 | |
| Re: hows this?
Hi yea I seen those but I don't want to lock my diffs. THANKS Quote: | |
04-08-2015, 01:16 PM | #9 |
Quarry Creeper Join Date: May 2012 Location: Houston
| Re: hows this?
I put 4 spider gears in my Mad Force 2.0 (nitro) and 50,000 in the diffs. Feels perfect. Tightened the diffs up a lot but they still break free when they need to. I would also suggest making a drag link to eliminate the slop in the steering. I replaced ALL the stock links with VP titanium links. No slop or wiggle what so ever. |
04-08-2015, 04:39 PM | #10 | |
ware did you get the rods and what ones? also how much did they run you? THANKS | |
04-13-2015, 12:14 PM | #11 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: hows this?
i use 1000000wt in my diffs. awesome! lays down power nicely, but still able to turn around when going slow.
hows this? - Similar Threads | ||||
hows the kit | vito | Axial Wraith | 27 | 12-07-2011 10:28 AM |
hows this motor | vito | Axial Wraith | 8 | 12-05-2011 10:45 AM |
hows this? | j_wamp | HPI Wheely King | 7 | 02-25-2010 03:13 PM |
So, Hows this for scale? | ClodTrasher | Tamiya TLT Crawlers | 22 | 04-02-2005 06:34 PM |
