Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: pinion question
Old 04-04-2016, 02:39 PM   #1
Default pinion question
so is there a drop in helical cut pinion gear that has a hole in it instead of the flat spot for the drive shaft?
Jmoritz is offline   Reply With Quote
Old 04-04-2016, 05:13 PM   #2
Default Re: pinion question
not that i'm aware of.i've been running kyosho nitro trucks for years,never had a need for the hole,but read where others have drilled them for driveshaft pins,but very hard material.hope this helps
thead is offline   Reply With Quote
Old 04-04-2016, 10:11 PM   #3
SuperShafty.com
um i think so. let me check the sticky... wait you can do that too. but ill look
mjderstine is offline   Reply With Quote
Old 04-04-2016, 10:16 PM   #4
SuperShafty.com
looks like all have the flat spot. i really dont think you will need a hole all the way through. i have never had one come loose in over 6 years of running these axles.
Old 04-05-2016, 10:19 PM   #5
SuperShafty.com
youre good man!
Old 04-07-2016, 03:00 PM   #6
I drilled mine out pretty easy to run Traxxas revo shafts. There is a how to out there on doing the revo shaft mid with instructions including the drilling. I will try to find it and post a link.
Sent from my VS986 using Tapatalk
raptorridr660r is offline   Reply With Quote
Old 10-11-2016, 01:17 PM   #7
Where is it?
STRAT is offline   Reply With Quote
Old 10-20-2016, 04:24 PM   #8
Originally Posted by STRAT View Post
Where is it?
Hey look at me being slow! Here is a link to the mod with all revo parts. Installing Revo Shafts
Another option is the Revo driveshaft yoke from RC Monster! http://rcmonster.com/proddetail.php?..._shaft_coupler
I used these on both the axles and trans sides of a New Era chassis truck I am putting together, but have not run it yet. I have also run the full Revo shafts as shown in the mod above and run them hard. No broken parts yet with 4s lipo and 2000kv motor. I am very impressed they hold up so well even after drilling out the plastic yokes.
Old 10-22-2016, 10:47 AM   #9
Originally Posted by twissted View Post
I have drilled them in order to use the Summit drive shafts that I also drilled to fit the pinion shaft.
Ur talking about the diff shafts(pinions), what pinions did you drill the silver ones or the black ones as the later are super hard!
Old 10-22-2016, 11:54 AM   #10
I drilled the hardened black ones. I got through the pinion shaft by grinding some of the flat first on my bench grinder then using a vice and a drill press to get through the rest of the shaft. Then I needed to counter sink one end of the hole in the shaft so the threaded end of the traxxas screw to sit in so it would be flush with the yoke. Be careful with drilling the counter sink, once you get through the hardend outter edge of the pinion shaft the bit will make short work of the center! Its much softer then the outside.
Old 10-22-2016, 04:04 PM   #11
Thanks man will try it but with a hand drill dont have a drill press
pinion question - Similar Threads
Pinion question shwng1973 Chit Chat 2 03-15-2012 07:10 PM
Pinion Question cby7715 Axial SCX-10 3 09-04-2011 07:52 PM
pinion question.. chris_dishmon Newbie General 4 11-28-2007 10:53 PM
pinion question krawlinCJ Tamiya Clod Buster 12 03-29-2007 08:31 AM
Pinion question..... BeadLock Tamiya Clod Buster 7 08-31-2005 08:23 PM
