| | #1 |
| Pure Pwnage ![]() Join Date: Sep 2005 Location: West Coast Canada
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Nov 2008 Location: Roswell
| where is everyone getting these? you have some special hook up somewhere? |
| | #3 |
| Driveshafts are he splined, with a length of "allen key" in the centre. ![]() Transmission have no gears, all reduction is in the worm gears in the axles ![]() ![]() ![]() Sorry for the crappy photos, will get some better ones tomorrow, it's kind of late here. Last edited by dave56bug; 11-19-2008 at 02:23 AM. |
| | #4 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| Those axles REALLY got me wanting one. Is there a way to reverse the input on the axle to flipp the diff to the passenger side? |
| | #5 |
| Quarry Creeper Join Date: Jun 2008 Location: phx
| that looks impressive. i wonder if it will not have torque twist b/c the driveshaft pushes/pulls on the ring gear. |
| | #6 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| | #7 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| Kinda crazy to have dogbone axles shafts. I like the simple direct drive tranny. |
| | #8 |
| Quarry Creeper Join Date: Jul 2008 Location: San Jose
| The axle design practically eliminates torque twist, replacing it instead with axle wrap. Since the torsional force from the driveshaft is converted to compression/tension (forward/reverse) force by the worm gear, there should be NO torque twist whatsoever. |
| | #9 |
| Newbie Join Date: Jul 2007 Location: Adrian
| Now you need a two speed tranny with this type of setup. |
| | #10 |
| Rock Crawler Join Date: Dec 2005 Location: Ventura County
| The dogbones are the same size as Kyosho used for their Twin Force Monster truck and the same size others have used for Super Class Twin Force crawler rigs. They held up pretty good in my Super Twin force rig and I would expect in a 2.2 application that they will hold up just fine. Time will tell. These are no TLT dogbones. They are thick and beefy. |
| | #11 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Are they short side shafts from the TF axles? |
| | #12 | |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
No, thats not right. Torque twist is caused by the gears resisting being turned by the driveshaft, not by the direction of gear load. They will have less torque twist because all of the reduction is inside the axle, thus making the drive shaft much easier to turn. | |
| | #13 | |
| It's a setup! ![]() ![]() ![]() Join Date: Jan 2004 Location: The Crawler State
On carpet I can go full throttle forward to full throttle reverse and the chassis doesn't move a bit. | |
| | #14 |
| RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
| I really like the axles |
| | #15 | |
The chassis has that bulky look, but the weight isn't too bad. Just two alluminum side plates and plastic chassis spacers/standoffs. The skid is alluminum. Last edited by John; 11-19-2008 at 12:31 PM. | |
| | #16 |
| Thanks for the reply John |
| | #17 |
| It recommends a 20-27t motor, I'm going to try my Novak Goat, and I also have a nice 19t that I might try out. |
| | #18 |
| | #19 |
| RCC Addict Join Date: Jul 2007 Location: where the SUPERS Reign SUPREME,,,
| how do the stock tires feel?????????? |
| | #20 |
| RCC Addict Join Date: Nov 2008 Location: never been
| the rig looks very robust, what is your take on the hardware supplied ? also is there a link where to buy the kit, all i find are pre-orders. TIA |
| Thread Tools | |
| Display Modes | |
