Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: whats ya'lls wb?
Old 11-22-2008, 11:15 PM   #1
Default whats ya'lls wb?
mine at ride height is 11-3/4" and with the links parallel its 11-7/8.
that is even with all the links mounted farthest out.
so.... pretty much i was wondering what everybody elses wb is coming out too, and if there's a way to make it 12.5"
goobs is offline   Reply With Quote
Old 11-22-2008, 11:21 PM   #2
I extended my back lower links. Wheel base is now 12 1/4" with links parallel.
John is offline   Reply With Quote
Old 11-23-2008, 12:06 AM   #3
How did you extend them?
killjoyken is offline   Reply With Quote
Old 11-23-2008, 12:09 AM   #4
11.5" in stock mounting position.
stampedeproject is offline   Reply With Quote
Old 11-23-2008, 12:15 AM   #5
Backed off the ball ends and installed spacers to extend the links.
Old 11-23-2008, 12:26 AM   #6
That's what I figured. I'm also guessing you spaced out the top links the same length too. What did you use for spacers? I don't think I've got anything with a 5mm bore.
