Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Beadlocks for the Kyosho Rock Force Solved
Old 11-22-2008, 11:47 PM   #1
Default Beadlocks for the Kyosho Rock Force Solved
If you are looking for beadlocks for the Rock Force, the new Pro-Line Epic Beadlocks (rears) work GREAT as a direct bolt on replacement for the Rock Force and drop the overall width by a 1/4" to around 10.5"-10.75" with the stock tires installed.
The Pro-Line regular beadlocks will also work but I think they give you some extra width.
In my opinion the Epic Beadlocks are WORLDS better than their regular beadlocks anyway.
stampedeproject is offline   Reply With Quote
Old 11-23-2008, 12:03 AM   #2
Have you mounted them up yet? I've got a set of 4 rears here that I can try. Looks like you'll just have to drill the hole out to 6mm for the axle stubs, but they should narrow the track width a lot more than the Pro-line eight shooters. Those were way too wide.
I'm just wondering how well they'll hold the bead.
killjoyken is offline   Reply With Quote
Old 11-23-2008, 12:07 AM   #3
Yep just drilled the hole and bolted them up... but my camera batteries died. Give them a try, the Epics are the best plastic beadlock you can buy in my opinion and hold better than some premium beadlocks I have tried.
Old 11-23-2008, 06:46 PM   #4
YES... DNA Wheelie King beadlocks and Badlands = total width of 10.5"
Old 11-29-2010, 07:59 AM   #5
Default beads
is this still the only way to get bead locks on a rock force?
riff_raff is offline   Reply With Quote
Old 11-29-2010, 10:18 AM   #6
Mayhem Eng.'s Avatar
No, Mayhem Eng. makes beadlocks for the R.F.
Mayhem Eng. is online now   Reply With Quote
Old 11-29-2010, 06:55 PM   #7
thanks
