| | #1 |
| Rock Crawler Join Date: Dec 2005 Location: Ventura County
| I competed in the Socal event at Stoddard Wells yesterday and tested out the Rock Force. The rocks were very challanging for even the highly modified rigs. Track width needed to be narrow in order to do well on the challenging rock courses set up by the SoCal and RCP Crawlers crew. A few mods that I recommend after the first day out. #1 Narrow your track width. With the stock Rock Force sitting at a 11" track width, I recommend getting a set of wheels with a pretty good offset. I talked with Proline at the event and I would highly recommend getting a set of their Slash wheels. The rears should work perfect to get the Kyosho width down close to 10 1/4". One note, the Kyosho stub axles are very short. I could only get about 3 ~ 4 turns on the hex nut with the stock wheels. Some of the aftermarket aluminum wheels will be too thick to get the outer hex on. You could mil down your aluminum wheels or purchase a set of plastic beadlocks like the Proline Slash wheels. #2 File down some of the sharp edges on the bottom skid. Also file down the screws that hold the skid to the chassis supports. Mine stuck out just a little and hitting it with a file brought them flush. ![]() #3 Extend the links. The Rock Force sits at 11 7/8" squashed. I made some plastic spacers for the rear that brought it out to 12 1/4". You could also add them to the front to get to 12 1/2". ![]() #4 Raise the steering linkage to above the knuckles. With the steering linkage at stock postion, I hit a lot of rocks on entry. Also, replace the large headed screws on the bottom of the knuckles with a round/flat head version. The stock large head screws did tend to hang up on a few things. ![]() #5 I laid down the shocks a little in the front and cut off the chassis were the stock shock mounting holes used to be. This was just a personal choice as I was able to lower the front portion of the Bug body that I used to run in the comp. ![]() #6 Raise the rear dig linkage and servo arm. This wasn't a huge problem as I only noticed the servo arm draging one time on one specific set of rocks. You could also make a skid plate to protect the linkage. I really like the rear disconnect design. It brings a full size servo to just above the axle case for lower CG. There is no additional weight with the dig mechanism as seen with other digs that mount to the tranny. ![]() Some pics from yesterday. The rocks were like razor blades and very challanging. I have a bunch of pics from the comp that I will post up later today. ![]() ![]() ![]() ![]() Since the truck incorporates a 3 link front set up, there is a lot of room in the front portion of the chassis to install your battery pack. You can mount a custom battery pack pretty low in the chassis, so that they lay about even with the front steering servo. I used a standard 6 cell stick pack for my tests, so my battery mounted at the top portion of the chassis. I am really interested in trying out the high speed gears. I ran a Kyosho X Speed motor which is probably equal to a 27 turn brushed motor and I felt I could use a little more torque. I think the high speed gears and a 35 or 45 turn brushed motor may be a good choice for those going with a brushed motor. I will test this out during the week and let you know the results. Last edited by John; 11-25-2008 at 11:02 AM. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Jul 2007 Location: where the SUPERS Reign SUPREME,,,
| thanx for the advice,,,over all how was the rigs performance,,were you pleased with what you went with??? |
| | #3 |
| Yes, overall pleased. I think once I get the gearing and motor dialed in, this rig will be able to compete with the best of them. Best of all, no broken parts. I really don't know what would break on this rig. The axles, driveshafts, worm gears, links, stub axles and axle cases are super strong and I really can't see many issues with them. |
| | #4 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| Dammit!! I asked Brian when the next Stoddard Wells one was and he didn't know. We wanted to go. |
| | #5 | |
| I wanna be Dave ![]() Join Date: Apr 2004 Location: SoCal
http://socalrcrc.org/forum/showthread.php?t=430 | |
| | #6 | |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
I don't believe that is true. .. | |
| | #7 |
| I am curious if the ones Stampedproject suggested were the fronts or rears. The offset is more on the rears. We had a set of the fronts that were drilled out and they gave us close to 10 1/2" with Losi Claws. We didn't have a set of rears that were drilled out, but the Proline rep said we should get another 1/4" less in overall width. I am ordering up a set for my Rock Force and I will give you the exact track width when I get them mounted. I modified my first post, until I have the slash wheels mounted and measured. Last edited by John; 11-24-2008 at 03:24 PM. |
| | #8 | |
| Quote: | |
| | #9 | |
I am also interested in the confirmed info, thanks John. I hate to see mis-information is all | |
| | #10 | ||
| I wanna be Dave Join Date: Jan 2006 Location: Henderson/Las Vegas, NV
Quote: OWNED!!! looks great john, i definetly wanna try to pick up one of these kits some time. i imagine with all the truck's gear reduction happening in the axles the torque twist is very minimal. | ||
| | #11 |
| Quarry Creeper Join Date: Nov 2006 Location: San Jose
| Drilled out the Proline beadlocks and mounted them up. I've still got the Switch tires on, but it actually looks pretty cool. Outside edge of tire to outside edge is 10 1/4". With some Panthers it would probably push it out to around !0 1/2". Not bad, but still not as narrow as I'd like. I'm still waiting to hear back from Vanquish about making custom wheels. ![]() |
| | #12 |
| Quarry Creeper Join Date: Mar 2008 Location: Hilo
| Nice, Im hoping Mayhem can make a set of Comp DP that will bring the track width down to 10.5~10.75. I have a set and really like the design. |
| | #13 | |
| | #14 |
| I'm using the rears. |
| | #15 |
| Rock Crawler Join Date: Sep 2007 Location: Omaha
| I used the Slash Epic Rear beadlocks with stock tires. Thinner Losi or Prolines will net you 10.25-10.5" width. Also DNA Stalker Wheelie King Beadlocks will work also. With the Stalkers and Badlands I am just under 10.5" Here is my previous post. Beadlocks for the Kyosho Rock Force Solved Last edited by stampedeproject; 11-25-2008 at 07:05 PM. |
| | #16 | |
| Rock Stacker Join Date: Mar 2008 Location: Its a language (not mine) and a utensil all rolled into one messed up city.
Hmmm I'll have to look into that, if I can even get a truck that is. Actually I had a question regarding the dig system... Naturally it wouldn't be as smooth as a switched dig for a Berg, but in comparison to the add-on Axial dig systems how did it function? Very informative write-up btw, so thanks. | |
| | #17 |
| Thread Tools | |
| Display Modes | |
