Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Rock Force Build with some Cow Bell...
Old 11-24-2008, 11:51 AM   #1
RC4WD Team Mgr/W.Pa.C.
Rckcrwlr's Avatar
Default Rock Force Build with some Cow Bell...
I was so intrigued by this rig that I just had to do it.
The idea of worm gear diffs made me take the leap.
Well, I picked it up at AB-C yesterday. First impression when I opened the box was good. Only disappointment is the wheel and tire selection. These will not be good for anything but bashing. They are a wheel with a real soft tire and no foams.
Rckcrwlr is offline   Reply With Quote
Old 11-24-2008, 11:52 AM   #2
Rckcrwlr's Avatar
First thing I noticed is you better make sure you have gear grease, thread lock, etc. This kit does not supply these items. A good grease is very important being that wormgears are known to heat up with excessive running. I am using RC4WD's Monster Lube.
Instructions are very clear as Kyosho has always been good at.
Old 11-24-2008, 11:57 AM   #3
Rckcrwlr's Avatar
So let's start with these axles... The gears are heavy metal...great tolerances...
Here they are... :gum:
Front Axle (Blue tape is to identify the front axle)
Rear Axle
Knuckles (for those of you that have had 1/8 Buggies...these should look familiar)
Old 11-24-2008, 12:09 PM   #4
Rckcrwlr's Avatar
The axles are set up pretty neat...the drive cup is enclosed in the axle case and then there is a dogbone that comes out to the stub axle...
These dogbones are massive...look at the compared to TLT's
Both axles are build...these things are heavy and bulletproof...
Speaking of massive...these are the links
Axles complete with links...
Old 11-24-2008, 12:11 PM   #5
Rckcrwlr's Avatar
Now comes the tranny or should I say the motor mount with a spur gear. To explain this, with the wormgear, all reduction is in the axles. This eliminates torque twist and also gives you the best drag brake around.
My first plan was to throw in a 35t warrior...they actually recommend a 24T. I figured, what the heck...and through in a 7T Puller... :wow:
The chassis consists of the Tranny? and several plastic cross supports.
Old 11-24-2008, 12:14 PM   #6
Rckcrwlr's Avatar
The driveshafts are an interesting design. They consist of two half shafts, a hex shaft and an aluminum sleeve. Great design.
Axles are on the chassis...
Shocks are a nice set up. The fronts are shorter than the back for better function. The come with aluminum caps and plastic bodies...they do offer an aluminum body upgrade. I am running 30 w Oil in them...
Shocks mounted on Chassis...
Old 11-24-2008, 12:17 PM   #7
Rckcrwlr's Avatar
The place where they tell you to mount the ESC and RX is two cross bars...I attached a piece of lexan to make it easier to mount.
Well, she is ready to go...
Love the sound of Wormgears...
Here is full speed with a 3s Lipo... :shh:
Old 11-24-2008, 12:18 PM   #8
Rckcrwlr's Avatar
The wheels and tires had to go...
I got my Mayhem Dbl Phattys with Rock Crusher tires and Kreepys. These things are heavy will be just add to the planted feeling...
Problem is that the RF has larger axles so I had to get the drillpress out and open them up...
Here she is ready for a comp...
Body is prepped for a coat of paint
Old 11-24-2008, 12:19 PM   #9
Rckcrwlr's Avatar
Well here she is:
Old 11-24-2008, 12:23 PM   #10
Rckcrwlr's Avatar
Findings...
The Puller is definitely the way to go. It gives you all the torque and still wheel spin. I may try a 4s to see if I can get some more top end speed.
I will definitely need a softer tire. Actually may give the OEM tires a try with some foam in them. They are pretty soft.
Waiting on the dig set up. We're having a Test'n Tune this Saturday so I will know better then.
Need to get another body for comps though... :-(
Old 11-24-2008, 12:30 PM   #11
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Nice posts. Very detailed.
What is your track width though with those wheels, has to be 11"+
Harley is online now   Reply With Quote
Old 11-24-2008, 12:31 PM   #12
Whats your track width with the Mayhem wheels? And what offset wheels are those Axial?
HiloDB1 is offline   Reply With Quote
Old 11-24-2008, 12:37 PM   #13
Rckcrwlr's Avatar
Thanks
Track width was just under 12"...I through these on 'cause I had them. Definitely not the right combo for this rig.
Old 11-26-2008, 12:52 AM   #14
very detail, thanks for your share!!!
Edison is offline   Reply With Quote
Old 11-26-2008, 11:39 AM   #15
nice rig, good job on the choice of engine make and paint job.
JOOTZ is offline   Reply With Quote
Old 11-26-2008, 12:11 PM   #16
Rckcrwlr's Avatar
Thanks guys...
I am really struggling on wheel and tire choice. Need to do some research.
Old 11-26-2008, 12:37 PM   #17
sods's Avatar
damn john, you get all the cool toys.
looks real good
sods is offline   Reply With Quote
Old 11-26-2008, 12:39 PM   #18
Rckcrwlr's Avatar
Originally Posted by sods View Post
damn john, you get all the cool toys, don't you?!
YEAP!!!
Old 11-29-2008, 07:47 PM   #19
Mayhem Eng.'s Avatar
What track width are you shooting for?
Mayhem Eng. is offline   Reply With Quote
Old 11-29-2008, 07:57 PM   #20
Scale'n
k9popo's Avatar
Holy shit, and I thought the hot racing axles were LOUD!!!
Great Job on the thread yo...
k9popo is offline   Reply With Quote
