Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Rock Force Hexes
Old 11-25-2008, 02:48 PM   #1
Default Rock Force Hexes
Any one have any upclose pictures of the Rock Force hexes? I'm running 14mm hexes on my 2.2 twin force (same stub axles) and switching to 12mm hexes would open up lots of wheel options. Are the rock force hexes drilled for an 8mm hole all the way through the hex or just in the round part of the hex?
Thanks
blue-beard is offline   Reply With Quote
Old 11-25-2008, 05:47 PM   #2
Thanks
I had another request for the part number and will see what I can do to get it for you.
- David
dkingston is offline   Reply With Quote
Old 11-25-2008, 06:02 PM   #3
FIRE the Bamster!!
Bart bender's Avatar
Jason posted these. The stub and the knuckle are TF parts so they would work for you BB.
Bart bender is offline   Reply With Quote
Old 11-25-2008, 06:19 PM   #4
I did see those pictures Bart Bender. I was kinda curious how much width they would add over the stock 14mm twin hexes. They kinda look like the pin goes through this round part of the hex. To me that seems to add a lot of width.
Old 11-25-2008, 06:30 PM   #5
FIRE the Bamster!!
I'll bet the adapter is a slot that slides over the pin. The part you have circled looks about the same size as the stub bearings. Maybe 3/16"?
Old 11-25-2008, 10:18 PM   #6
TEAM MODERATOR
Reflection's Avatar
Blue Beard,that is where the hex pin resides. Kinda goofy hexes IMO. Drilling out 12mm hexes or custom 14mm beadlocks seems like a better option if your worried about width.
How'd them adapters work?
Reflection is offline   Reply With Quote
Old 11-26-2008, 12:30 PM   #7
Pure Pwnage
dave56bug's Avatar
I quickly looked at some 12mm axial hexes I have, and they would be a very simple mod, might do it tonight, and post some pics...
dave56bug is offline   Reply With Quote
Old 11-26-2008, 05:54 PM   #8
TEAM MODERATOR
Reflection's Avatar
It may work,probably the best bet would be to just drill out the grub screw hole to the correct size of the pin. The pin in the Kyosho stubs dwarf the Axial pins a good deal. If that don't work,I think the next best thing is to take a small end mill and open up the slot. After drilling the hole out for the monstrous pin and then drilling them out to 8mm,there won't be much left of the 12mm hex. I ran into that when building my 2.2 Twin Force. It worked,but the hex broke easily. Best thing IMO is to use 14mm wheels.
Old 11-26-2008, 05:55 PM   #9
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
yeah, 14mm hexes seem to be the best bet. These RF stockers look good though.
JohnRobHolmes is offline   Reply With Quote
