| | #1 |
| Rock Crawler Join Date: Dec 2007 Location: Dayton, Ohio
| I have been following this site for about a year and a half and been a member for about a year. I know what I am going to suggest might sound a little foreign to some of you but I would appreciate it if you at least keep an open mind as to my opinions on the Rock Force. The first thing you need to understand is that the engineers at Kyosho have spent nearly 3 years developing this product. By the time some of you saw the Super "prototype" over a year ago, there had been well over a year in development. As they watched the market change, the emphasis was made on developing a competitive 2.2 crawler that would work extremely well, right out-of-the-box. When I say the engineers have been working for 3 years, I mean that they have hand built prototypes, much as the pioneers on rccrawler have for many years as well. They took what they learned and made improvements. What you see today is the evolution of their findings. While there are things that may seem a bit "odd" to most of you, I assure you they have been thoroughly tested, revamped, improved, rinsed and repeated. Examples: - Wheelbase and track width, while I know and understand that the conventional wisdom up until now has been to maximize the wheelbase to meet the USRCCA standards, thy Kyosho stock wheelbase and track width has been tested in virtually every conceivable combination and what is stock in the kit is what they felt the most optimum starting setup should be. Wheelbase, track width and ride height are three aspects that need to work well together to make sure that a rig that crawls well, sidehills well and vice versa. The super class has proven that longer wheelbase isn't always best. There is a point where a particular vehicle performs better, even if it isn't the longest possible wheelbase. - Wheel speed a la gearing, It is true that wheelspeed has been a very important factor for most in rc crawling, take a moment to consider the trade-off between wheel speed and torque at the wheels. Example, when high-centered and rocking the rig, it isn't the wheels speed that helps get you free, it is the torque generated at the wheels. The worm gear setup that Kyosho has used provides the maximum torque at the wheels and the least possible torque in the chassis. I know there will be several who will cite examples where wheel speed it important and I won't try to claim you are wrong. This is just the opinion of the engineers. I know that the expectation of any new rig is that you must tweak, fiddle and modify things to make them fit the paradigm you are used to. Please understand, while some of the individual components came from other Kyosho vehicles (wheels from DBX, etc..) the major components and the crawler as a whole were completely designed for the specific use of rock crawling. This is a first in the rc crawling market. So, what I am asking for you guys who are currently building or have built your rigs; try them as stock as possible and give them a shot that way. The gearing is that way on purpose, the width is where it is at to match the wheelbase in generally a optimal of a configuration as possible. Is everything going to be perfect for every driver? No. Is the kit, out-of-the-box a great starting point? Yes. Please resist arbitrarily modifying things because that is what you are used to doing. I think you will be pleasantly surprised and your overall satisfaction will be much greater. This was not a kit thrown together to exploit a market. It is a thoughtfully designed, carefully engineered, precision crawling machine. - David |
| Sponsored Links | |
| | #2 |
| support@rc4wd.com ![]() Join Date: Nov 2007 Location: Lancaster, Ohio
| Did you get that thing built yet Dave Great write up buddy. Hope to see the rig soon. Uhh I mean you |
| | #3 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| If I had one, I would change the gearing right away. |
| | #4 | |||||
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| Seems like a great place for discussion. Quote:
I would like to hear why they thought that the shorter wheelbase was an advantage. Super is really a whole different story, you are talking about significatly different wheelbase lengths that has no maximum. Not saying it was just a completely wrong choice to go to with what they have but I would be interested in finding many people who would agree that 12.5" was not the way to go. Quote:
Having so much reduction at the axles is awesome! However the gearing is really was to low. I see on the Kyosho FAQ section it says that with the low gear there is "No need for an expensive motor". I don't quite understand what they are talking about, they could have went with a much more reasonable 60:1 - 80:1 range and used "standard issue" 55t lathe motors, had at least a little wheel speed (because it has NONE now) and still have plenty of torque. Quote:
The kit does seem decent out of the box, but even after my initial impressions it still does need quite a bit of tuning like every other kit that has been released. Even though the parts were completely designed for this kit there are still things that people can already immediatley see need changing for this thing to perform well. Tweaking right out of the box is still needed. Quote:
I still think they should have rethought the trackwidth and wheelbase. The people on this board have tried countless setups. More than 10 engineers could try in 3 years, there is a consistency to peoples truck not just because it is what everyone runs but because it has proved itself over and over. Watch nationals every year, I am guessing you won't see too many 11" wide 2.2's competeing with wheelbases under 12". Quote:
It does seem like a great kit, and a great starting point. With a good bit of tweaking it will hold its own with the most popular of the 2.2 comp rigs out there. Probably the 2nd best crawling kit I have ever seen. I am willing to bet that soon these will be much like Axials you see at comps, obvious what they are based on but far from looking like the original. It is just too hard for major manufactures to keep up with advancements of such a fast evolving section of the hubby. There is my $.02 | |||||
| | #5 | ||||
Axles. I just want the axles. And maybe the tranny plates. | ||||
| | #6 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| i dont think it was "thrown together to exploit the market". it seems like alot of time and thought went into this kit . but you must understand eveyone has a setup they like and tweeking and tinkering is part of our hobby. i have never seen two builds that where exactly the same even with the same parts . its just part of the hobby not ment as disrespect to kyosho or the engineers. just my .02 |
| | #7 |
| Quarry Creeper Join Date: Oct 2008 Location: Marysville
| | #8 | |
I am sure they expect people to make tweaks, but it almost sounds like they think it is comp ready (competitive) out of the box, and I would disagree with that. I still like the truck and look forward to putting in a bunch of hours on it over the long weekend. Last edited by Harley; 11-26-2008 at 02:52 PM. | |
| | #9 |
| Quarry Creeper Join Date: Mar 2008 Location: richmond
| how is the parts and screw bags laid out? im a red army guy too, and one thing i have learned about kyosho is they are proud of thier stuff and the price's show this!nothin kyosho sells is cheap nor cheaply made. im a nitro racer as well as a crawler and on the 1/8 scale scene, kyosho's are IMO the fastest trucks out there with plenty of R&D behind them!i run thier newest truck<st-rr> and its a nightmare to put together cause of the way the packaging was. difficult but damn fast! |
| | #10 | |
Am I wrong? | |
| | #11 |
| Quarry Creeper Join Date: Mar 2008 Location: Hilo
| The parts a packaged by components. Axle parts are in 1 bag knuckles and associated parts are in another and so forth. Its not that hard to figure out with a little help from the instructions |
| | #12 |
| Quarry Creeper Join Date: Nov 2006 Location: San Jose
| Well, Harley and John pretty much covered my thoughts, so I think I'll stay out of this one, especially since my RF is completely torn down and I've been making new parts and mocking up a new chassis. I've got one question for you David: Have you driven a stock RF side by side with another comp crawler? |
| | #13 |
| Rock Crawler Join Date: Sep 2007 Location: Omaha
| All good points and fair enough... they did thier homework. One thing Kyosho has to realize is that this, the RCCrawler National Network, LIVE to modify. In fact, I think if God himself came down and delivered a perfect crawler, you would still hear things like, "yeah it's too perfect there is no challange... so I went back to Rock Lizards and changed all the links to plastic." One thing for sure, no one is bitch'en about the drivetrain not being strong enough, geez it's HUGE. To the Gear reduction point I think Kyosho wanted you to be able to use some pretty weak motors and still get the torque - good idea, however I tend to agree with Holmes that a a blip on the throttle can get you out of a number of jams. I think you left out the front end geometry. As I posted in a previous post - I am a little surprised to here people already complaining already about the front link setup. From an engineering perspective this is a superior link setup and so good that only the most expensive and advanced 1:1 Formula 1 off road Rock Racers (crawlers) use this setup. http://www.pirate4x4.com/forum/showt...pbell+buggy%22 and is one reason that even with a 4.5R Novak Brushless system I had zero chassis torque twist... it was dead flat. Perhaps with the chassis running dead flat and the shorter wheelbase, maybe it will run a little better. In theory a shorter wheelbase should lessen high centering issues. Time will tell. I am committed to beating this rig in stock state to see how smart those guy in Japan are. ;) At any rate Kyosho did some really good work that everyone will have a blast "tweaking" to thier own needs. |
| | #14 |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| The Rock Force SP2 should be cool. |
| | #15 |
| Pebble Pounder Join Date: Oct 2007 Location: Bay Area
| The other downside related to this is those of us with FXR's are limited to 35T on 3S based on Mfg recommendations. I really don't want to buy a FXR Pro just to run these axles out of the box. |
| | #16 |
| Guys relax... I wasn't trying to claim that the Rock Force was going to go out beat everyone right out-of-the-box. If you re-read my post, I was just asking for people to try it in (relative) stock form before dismantling it, part and parcel. Feel free to modify what you wish. That is why the other worm gears are available, that is why there are more option parts coming. Nobody will ever claim it is "the best" out-of-the-box The guys who designed this crawler came from the same place most of you have. They scratch built crawlers (for fun and work) over several years. They are more familiar with how you guys want to build and tweak than you would ever imagine. ....and yes, I have driven it side-by-side with my comp OCM/Berg. - David |
| | #17 |
| Poor David... just trying make a point and as always someone (throat clear,- Holmes throat clear..) has hijacked a post. LOL... Brother David we are with you in spirit. All us arm chair engineers (a whole forum full) picked apart the AX10 the same way at first. |
| | #18 | |
The Kyosho will be no different. The axles will be used to build some sweet rigs. The rest will be made better by the "armchair" engineers as they are the ones who actually have first hand experience and an understanding of real word needs. | |
| | #19 | |
| Rock Crawler Join Date: Apr 2005 Location: Upland
| Even Kyosho's 1/8-scale buggy/truggy and all their other race kits need tweaking out of the box to get them to perform at their best. Everyone drives differently and on different terrain. So tweaking is needed. Even at the 1/8-scale worlds (and other similar events) the box setup isn't run, or if it is then rarely. Quote:
| | #20 |
| I actually like having all the gear reduction in the axles. I am running a 35t pinion and a 72t spur for a final ratio of around 60:1. I dont think thats all that bad. Like posted many times already just have to tweek it to where your happy with it. I have no doubt out of the box it will performe fairly well but that doesnt make it the end all be all kit. |
| Thread Tools | |
| Display Modes | |
