Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: My Rock Force Super Sized
Old 12-02-2008, 06:39 PM   #1
Default My Rock Force Super Sized
Chassis... Custom
Axles...Kyosho Rock Force
Gearing.... (Optional High Speed Gears) 18T Pinion, 86T Spur Total - 71 ~ 1
Wheel Adapters....RCP Crawlers 17 mm
Wheel Base....17"
Track Width.... 13"
Belly Clearance .... 4 1/2"
Clearance under axle pumpkin... 2 7/8" with Moabs (I have some XL's on order to bring it up)
Motor.... 7t Cobalt Puller (Holmes Hobbies)
ESC....FX-R
Battery.... 2 cell 2200 Lipo (Holmes Hobbies)
Dig.....Kyosho Optional rear disconnect
Wheels....Axial Beadlock (narrowed)
Still a work in progress, but coming along. I want to try the truck with no rear steer and just front dig, to see how it performs. I also kept the the 3 link/panrod stock set up to see what torque twist is created. I have some parts on order and on the way. Should have some performance results shortly. May need to widen the track width with some longer hexes. I am also thinking of making thicker rear links to match the fronts.
The 17 mm adapters by RCP Crawlers are a nice fit for the Axial wheels. These adapters are also used for Clod Axles incorporating Thunder Tech CVD's. The large nuts on these adapters tend to come loose from the big wheels/tires even with lock tite, so I am backing them up with the stock Kyosho Rock Force hexes for added protection.
The chassis is part of my 2.2 design shown below. The 1/4" thick chassis extensions bolt to the 2.2 frame. I designed the chassis to convert for a scaller build of mine, but it appeared to set up nice for this super since I needed the extra chassis length for the panrod set up.
John is offline   Reply With Quote
Old 12-02-2008, 07:36 PM   #2
I was wondering when someone would do this.
2JSC is offline   Reply With Quote
Old 12-02-2008, 08:27 PM   #3
TEAM MODERATOR
Reflection's Avatar
Little different than I had planned,but it should be a good start. I'm curious about how the 3 link will work. That puller should wizz them tires at that ratio.
Did you get the dig shifting better? I still think a dig at the tranny is a better option.
Reflection is offline   Reply With Quote
Old 12-02-2008, 08:47 PM   #4
What do you have planned Steve??
BeeRC is offline   Reply With Quote
Old 12-02-2008, 09:07 PM   #5
Interesting. I have my rig built and I am trying to decide on electronics. I may go with another chassis as well. LOOKING GOOD ! Keep it up.
PINKY is offline   Reply With Quote
Old 12-02-2008, 09:27 PM   #6
TEAM MODERATOR
Reflection's Avatar
How many slots are in the dig plate john? Maybe you've posted pictures of it somewhere. It'd help to see it. Not saying dimples wouldn't work,that might be a good idea.
I could tell ya,but I'd have to kill ya. Sorry,no peeking.
Old 12-02-2008, 09:59 PM   #7
Kamikaze's Avatar
Hey John, Raptorman, 2004 called, they want there supers back.......
J/k, I can't wait to get my hands on one of these.
Kamikaze is offline   Reply With Quote
Old 12-02-2008, 10:40 PM   #8
Hey, I remember supers...didn't they go extinct with 11" wheelbases, super low gearing and big, heavy chassis? :-P j/k (about the supers)
Looks interesting, but you definitely need to find a way to widen that bad boy!
killjoyken is offline   Reply With Quote
Old 12-03-2008, 07:43 PM   #9
TEAM MODERATOR
Reflection's Avatar
The beauty of running Rock/Twin/Mad Force axles is they are dang near 1:8 scale buggy solid axles. Wideners for 1:8 scale buggies are available in different widths and just about anywhere you look.
He's at 13" wide. My super is at 13.250 and I feel it's to wide. But I also feel even the older,smaller Moabs are to big.
Old 12-03-2008, 09:18 PM   #10
Release your anger..
ThinkTank's Avatar
John, Are the outputs on the tranny 8mm like on the TF?
ThinkTank is offline   Reply With Quote
Old 12-03-2008, 09:36 PM   #11
RF outputs are 6mm.
If your looking for shafts, I believe the revo's are 6mm. I could be wrong. I have a pair here, but I drilled them out for my old TF crawler build, so i don't remember what they were originally.
Old 12-04-2008, 09:41 PM   #12
TEAM MODERATOR
Reflection's Avatar
Originally Posted by John View Post
RF outputs are 6mm.
Your right. Just drill the flats out of the Revo's are your good.
Old 12-09-2008, 08:26 PM   #13
FIRE the Bamster!!
Bart bender's Avatar
Can't believe I missed this. God bless you John for building a SUPER!!! Looks great. With your connections I'm surprised you don't have some fantastic new Super Tires.
Bart bender is offline   Reply With Quote
Old 04-14-2009, 09:05 PM   #14
corkysk8's Avatar
Was this ever finished?
corkysk8 is offline   Reply With Quote
Old 04-15-2009, 12:19 AM   #15
here is a link to their site, looks like it never got finished. IBD
http://www.rcptracks.com/rcpcrawlingchassis.html
JOOTZ is offline   Reply With Quote
Old 04-15-2009, 11:24 AM   #16
Now this is definitely a Force to be Rockened with.
Great job.
Carl
quickster47 is offline   Reply With Quote
