Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: New Rock Force
Old 12-20-2008, 08:53 AM   #1
Default New Rock Force
I got the Rock!!!!!!
I was thinking of putting a Traxxas 2075 E-Revo servo (waterproof) and the XL-5 Electronic Speed Control (waterproof) will the tork of that servo be ok (115lb) I have a FLM Savage that has a Hitec 5955tg it is great but not water proof and alot of cash. Do you guys will Rock Force feel I will be ok with this set up
saydee1800 is online now   Reply With Quote
Old 12-20-2008, 10:49 AM   #2
For regular crawling the 2075 should be fine. I'm running one in my x-trail and it's got just enough power for most situations. In some situations it will just stall out though and since the splines are plastic you risk stripping them, especially during tumbles. I run the 5955tg in my comp rigs and it's perfect. I think some of the Hitecs are water resistant, but I'm not about to test that on a $100 servo. Funny thing is that I robbed the 5955s out of my FLM Savages for my crawlers. Needless to say, my Savage doesn't turn so well now with a 190oz servo. :-( Once the 7950 comes out (400oz!) the 5955s can go back in the Savages.
The XL-5 should be fine in the RF. The only things that suck are the 8.4v limit and having to double pump for reverse.
killjoyken is offline   Reply With Quote
Old 12-20-2008, 06:51 PM   #3
the highend hitecs are waterproof if u look on their website they got like 8 or 9 o-rings on them. and i know cuz i've run mine underwater.
goobs is offline   Reply With Quote
Old 12-20-2008, 06:57 PM   #4
TEAM MODERATOR
EeePee's Avatar
So you intend to run your new $400 Rock Force in water?
Truth be told, the Traxxas stuff is crap for crawling. Servo is weak, and double pump reverse is a TERRIBLE thing.
EeePee is online now   Reply With Quote
Old 12-20-2008, 07:06 PM   #5
Quality electronics will last you through several rigs if you take care of your stuff.
EeePee was kind of curt but very accurate. Put the best electronics in your rig, that you can afford. You won't be sorry in the end.
- David
dkingston is offline   Reply With Quote
