| | #1 |
| I wanna be Dave Join Date: Dec 2008 Location: ?
| I have order the dig and a Hitec HS-5645MG I have a Futaba 3PM 2.4 Fasst Controller How do I get this to work? |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Dec 2007 Location: Dayton, Ohio
| | #3 | |
Setting the EPA for CH3 (SW2) from the manual... 3rd channel servo (EPA) adjustment (Preparation) - Select setup item "3C-L.F.U" and make the following adjustments: (3rd channnel initial setup: SW2) 1 3rd channel servo (up side) adjustment Use the (+) and (-) buttons to adjust the steering angle. 2 3rd channel servo (down side) adjustment Select setup item "3C-R.B.D" and use the (+) and (-) buttons to adjust the steering angle. 3 When adjusting the EPA of another channel immediately after this, see the adjustment method for that channel. When ending adjustment, return to the initial screen by pressing the (SEL) button. ![]() I hope this helps! - David | |
| | #4 |
| Looking for scale goodies ![]() Join Date: Dec 2006 Location: In Cali.
| WOW!! David is all over that!! |
| | #5 |
| | #6 |
| thanks you guys seam really great |
| | #7 |
| Glad to help! - David |
| | #8 |
| RCC Addict Join Date: Nov 2008 Location: never been
| this is waaaaaaaaay great customer support. kudos to David and kyosho, all the more reason to get a rockforce post edit- i did get the rockforce... Last edited by JOOTZ; 01-19-2009 at 03:14 PM. |
| | #9 |
| Just trying to be helpful! - David |
| | #10 |
| | #11 |
| I gotta be honest, at this point I cannot recommend any brushless system. I know a MM with 55T 45T 35T and maybe down to a 27T would work well because either I have run them or people I know and/or have seen, run them. Using the chart below: ![]() I would start with the HS gearset, probably a 25T pinion and the stock spur. That with a 35T motor should give you the wheelspeed you are wanting in a package that isn't overgeared. Give that a try (should be cheaper for you as well) and let me know what you think. - David |
| | #12 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| david , i just purchased a rock force , its not even here yet but i have to tell you thank you for reinforcing my decision to purchase this kit . you have been more than helpfull to others and i have learned much from yours and other (killjoyken thanks dude) posts and coments. you go above and beyond and thats where this kit will go. (sorry harley jmo) the more positive you keep it the further it will go. so thanks..... |
| | #13 | |
| RCC Addict Join Date: Jul 2007 Location: where the SUPERS Reign SUPREME,,,
| | #14 |
| Does any one have this controller running with this kyosho dig? I can't seam to get it right |
| | #15 |
| what radio? the futaba? endpoint adjustment is all that is neccesary . i use a dx3r and all idid was set my endpoints so that the servo puts just a touch of pressure on the fuel tubing ant the end of its throw each way and the center set so it is in free wheel mode. |
| | #16 | |
| | #17 |
| is there an option tho change the switch to 3 position . sound like its only sposition now . ill look up a manual and see if i can do it. |
| | #18 |
| so i looked at the manual also and davids instructions look like all you can do. using the sw2 switch. if you start with the servo horn in the center then set your up and down epa's .thats all i get from it .it looks like you can make it 3p though hope it helps. |
| | #19 | |
i`ll let you know what happens when i get to that point, ima prolly bring it to my LHS and their tech guru and have him program it ($11/hour). | |
| | #20 |
| dude my guys do it for a chicken sandwich from BK ($11) that bites |
| Thread Tools | |
| Display Modes | |
