Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Step 24 (shocks) of build ?
Old 12-26-2008, 09:56 PM   #1
Default Step 24 (shocks) of build ?
On step 24, am I supposed to file off 0.7mm opposite of the already flattened side of the shock piston? Why was this not already done?
Thanks.
dhoweird is offline   Reply With Quote
Old 12-26-2008, 10:05 PM   #2
TEAM MODERATOR
Reflection's Avatar
IMO,thats a personal tuning tip. Not really necessary. Thinner shock oil will give the same results as putting another flat or a bigger flat. Try it stock and see how you like it. If the suspension is to slow for your driving style,add a flat,make the original flat bigger or use thinner oil.
Just food for thought,a slower suspension will let you carry a wheel over holes and that can be a BIG help at times.
Reflection is online now   Reply With Quote
Old 12-26-2008, 10:12 PM   #3
GREAT, thanks... I plan on using 20w oil.
Now back to it.
Old 12-26-2008, 10:25 PM   #4
These pistons are used in another application for Kyosho where filing isn't necessary. I haven't done mine and may not.
A tip for building the shocks:
1. Build the shock and full it with oil until it is a little more than 1/8 from the top.
2. Slowly cycle the shock shaft several times to release any air bubbles under the piston.
3. Bring the piston up about half way, place the bladder on top of the shock, slowly return piston to bottom creating a vaccum on the bladder.
4. Carefully screw on cap.
This is the best way to build these shocks IMHO. Let me know how it works for you!
- David
dkingston is offline   Reply With Quote
Old 12-26-2008, 10:29 PM   #5
TEAM MODERATOR
EeePee's Avatar
Yeah I didn't file mine down, and don't plan on it. I use 15 weight in front, and 20 weight in back. Instead of filing a flat, I'd drill a hole anyways, that way you know it's exactly the same all the way around. Drilling a hole, or filing another flat would open some tuning options, but I don't think I need it.
EeePee is online now   Reply With Quote
Old 12-26-2008, 11:01 PM   #6
Thanks for all of your input, step 24 is now complete.
Old 12-27-2008, 03:58 AM   #7
greasypete's Avatar
I did that:
on all four dampers and used a thicker oil in the back. I like the dampers faster.
greasypete is offline   Reply With Quote
Old 12-27-2008, 09:40 AM   #8
TEAM MODERATOR
EeePee's Avatar
What size hole you got there Petey? Just out of curiosity.
Old 12-27-2008, 01:25 PM   #9
TEAM MODERATOR
Reflection's Avatar
Thats obvious. That hole is huge for a shock piston. I generally use a 1mm drill at the biggest when I adjust the pistons.
Old 12-27-2008, 01:27 PM   #10
TEAM MODERATOR
EeePee's Avatar
Thats what I'm saying! I wanted to know what not to use!
I'm thinking pinholes if I do, but again, I don't see the need.
Old 12-27-2008, 01:34 PM   #11
TEAM MODERATOR
Reflection's Avatar
1mm is pretty small. On a few trucks I've built,I've needed 2 or 3 1mm holes to make it work right. Other trucks,that was to much. Kinda time consuming,but starting with one 1mm hole then adding if needed is what I like to do.
Or,you can take the easy way out and just swap to lighter oil if it's to slow. I've done that on some set ups and it's worked just as well.
Old 12-27-2008, 05:14 PM   #12
greasypete's Avatar
Right, that is a 2mm hole. You can always make the shocks slower with thicker oil, but if you have your hole to small for the thinnest oil, you need to disasmble them complete to drill a new hole
Pete
