Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Integrated Delrin Skid Plate
Old 12-27-2008, 03:18 PM   #1
RC4WD Team Mgr/W.Pa.C.
Rckcrwlr's Avatar
Default Integrated Delrin Skid Plate
I have developed a Prototype Delrin Skid Plate that eliminates the bottom supports. Remember that this is a prototype.
Using the OEM skid as a template...that is about as far as it went...
To eliminate the bottom supports I needed to use 3/8" Delrin and then notch it.
The elimination of these three supports and adding the delrin puts more weight down low...
I needed to angle the area where the links are to avoid binding
Test fit
To support the tranny plate I notched to tight tolerances to make sure there is no slop...also had to make room for the spur gear and needed to taper it for easy removal, if needed.
Here is the fit...
Rckcrwlr is online now   Reply With Quote
Old 12-27-2008, 03:28 PM   #2
Rckcrwlr's Avatar
Here is the topside of the plate
As you can see it is tapered to the angle of the OEM skid
Here it is mounted (Side view)
It is slightly thicker than the OEM Alum one but I will be rounding the edges so that isn't "hanging" down.
Here is the bottom view...note that there no sharp edges and screw heads
Like I said above...I will be rounding and tapering the sides to avoid the possibility of snagging.
When I get a chance, I will post up a comparison of weight differences. This is a big chunk of Delrin creating a low CG...
Old 12-27-2008, 03:30 PM   #3
Rckcrwlr's Avatar
Time to get the file out and clean up all the rough cuts...
Old 12-27-2008, 03:30 PM   #4
slippery is good. do you need the pieces front and rear? seems like you could streamline it a little more. but for a proto it looks great
BILLYGOAT is offline   Reply With Quote
Old 12-27-2008, 03:39 PM   #5
Rckcrwlr's Avatar
That was my thinking too...but you can always remove them...
Chances are it will be cut off and the edges rounded but I want to see how it goes as in OEM format.
Old 12-27-2008, 04:31 PM   #6
Good thinking! Keep the ideas coming!
- David
dkingston is offline   Reply With Quote
Old 12-27-2008, 04:39 PM   #7
Rckcrwlr's Avatar
- David
There is something to say about thinking alike...
Old 12-27-2008, 05:14 PM   #8
with the taper on the front and read edge it might help slide over stuff . great work .
Old 12-27-2008, 05:35 PM   #9
TEAM MODERATOR
EeePee's Avatar
Not bad John, ugly, but not bad!
EeePee is offline   Reply With Quote
Old 12-27-2008, 08:26 PM   #10
dezmoon's Avatar
thats awesome,,,,i used the stock plate,,,just threw some team associated chassis guard on mine,,its a slim film that is used on race chassis,slick like grease..but no added weight
dezmoon is offline   Reply With Quote
Old 12-27-2008, 11:16 PM   #11
Rckcrwlr's Avatar
I'm not in it for looks...
Old 12-27-2008, 11:19 PM   #12
TEAM MODERATOR
EeePee's Avatar
Awe come on... If you don't look good, you don't feel good! [/Crystal]
