| | #1 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| After lots of reading and learning from others triumphs and failures, i pulled the trigger and bought a rock force(thanks kalani). first i have to say that the kit is in true kyosho style. instrictions where very thorough and easy to follow once you figure out the pictograph code. its crazy how beefy this thing is. i wanted to start with the kit stock and then make small changes till i get it where i want it. it is fun stock but i feel like the high speed gears are neccesary as others have said already.for now i will be happy until the hsg set arives. so far the list looks like this..... kyosho rock force kit Vanquish Products DH 2.2 comp wheels with berg offset mamba max spektrum rx 35t motor with 78/26 gearing 3cell lipo or a123 rovers(these things flat hook up.) stage killa comp body(to stay legal.) dx3r kyosho dig w/645mg ![]() ![]() ![]() thanks everyone who has answered question and helped make this rig happen. (vanquish products, killjoyken,david from kyosho,and everyone else in the rock force therad.) Last edited by Tanis; 12-31-2008 at 08:02 PM. Reason: fixed pics |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Oct 2007 Location: Bay Area
| Looks like a good setup. How is the 645 doing for dig? Is it having any troubles when on a incline? Are you using the 335 or 460 hex spacer on the VP DH's? |
| | #3 |
| thanks dude. the 645 is ok . still getting the dig dialed in . it does require a little finesse to get it to disengage. think i will try a 7955 or 8711 and see if that does it . i am using the 335 hex spacers . |
| | #4 |
| RCC Addict Join Date: Jul 2007 Location: where the SUPERS Reign SUPREME,,,
| nice,,,,how was installing the dig?? |
| | #5 |
| | #6 |
| RCC Addict ![]() Join Date: Sep 2007 Location: WHEAT RIDGE, CO
| JOHN, JOHN, JOHN......What's next dog:-P Bringing it Sunday? |
| | #7 |
| Rock Crawler Join Date: Dec 2007 Location: Dayton, Ohio
| Looks AWESOME! Welcome to the Rock Force Red Army! - David |
| | #8 |
| | #9 |
| Quarry Creeper Join Date: Nov 2006 Location: San Jose
| Since I'm half chinese I'm not sure if I want to be part of the "Red Army". John: Looks good. Don't worry, we'll all make this rig a Force to be reckoned with. Are you running the stock foams with the Rovers? I mounted up a set on my RF but tried NWTT hybrid foams with a sliver of regular foam on the outside and had problems. I've gone back to the stock foams and moved my shocks inboard since the massive Rovers pulled my lower shock perches off and gave me an unsprung droop that killed my last test session. I'm also having issues getting in and out of dig. I'm running a 200oz Airtronics but it won't pull it out of dig with any load on the wheels. And with the extra play from the HS gears plus the play in the dogbones it sometimes takes a full revolution of the wheel to engage. I'm not sure how to fix this yet. Maybe we need to start a thread about dig tuning. |
| | #10 | |
| | #11 |
| [HOONIGAN] ![]() Join Date: Jan 2008 Location: Littleton
| Dude.... Thats killer, how is the esc and motor combo working. I can't wait till Sunday so that you can let me drive it |
| | #12 | |
thanks dude. did i see yours for sale? so i have put 3 packs through it (2 3s a123 and 14s a123.)and so far i like it alot . mods so far include .... I drilled a 1/16 hole in the shock pistons. with 25w shock oil. seems to be perfect for my driving style. I added 3 1/16 " spacer on the rear lower links .wheelbase is right at 12 3/8" i am running the Vanquish dh 2.2 pro-comp with 4 weights in front and 2 in back.and the 356 hex spacers . it gives me 10 7/8 width. i would like it to get to around 10 to 10 1/2 . i have some ideas so keep checking back. tires seem good but i think it need some different foam. they keep getting better the more i use them. so on to the dig... well at first it seemed like i would need tons of torque to engage and disengage it but the more i use it the more i understand that its not the same dig i have been using. shifts from 4x4 to ft wheel drive fairly easily . i believe it will get better as it breaks in. from neutral to lock is easy but from lock to neutral it is a little sticky. because when you dig it binds the rear axle i found that a little wiggle of the front servo gets thing moving most of the time. on an uphill i as others had to just give the throttle a touch or reverse. this is my only real complaint so far . i am not sure if a metal shift fork will hep but the less flexible material seems in order. i am back to the 645. i didnt see enough improvment to warrent a $100 servo. i used non silicone fuel tube instead of springs and set the endpoints on my 3rd channel and i think for now shes good to go. i will give it 10-15 packs to see how well it loosens up. in conclusion... i think this rig has tons of potential. and i will soon join others in aftermarket chassis and build up. but for now i think stock is a great start. | |
| | #13 |
| Rock Crawler Join Date: Nov 2007 Location: San Marcos
| Cool rig John, How about some off body pics? That would be nice, I want to see what it looks like underneath. |
| | #14 |
| Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
| | #15 |
| well she made it to her first comp. installed a 5t cobalt puller and thing went i think well for the first time out . wheel speed was a little slower than i needed. couldnt really get much dig out of it with the wheelspeed . motor didnt heat up much. pullers run a little hot but,i could still hold my finger on it for a 2 count. mamba max was flawless. i did the dk link mod on the rear . much less axle steer. rig felt and drove very solidly and predictablly. i think a little faster movement in the suspension. i finished 2 of three courses and feel that this rig still has lots of potential with only a few small mods . i didnt want to think the high speed gears are necessary but i will have to wait and see. my overall opinion is still very high and i have big hopes for this rig. so dont go selling your rock force ...youll be buying another one if you do. BEEFY,SOLID,STABLE |
| | #16 | |
- David | |
| | #17 |
| im taking her out for the second comp. i put a 4600kv castle brushless in it with a 78/23 spur pinion. great wheelspeed on 3s a123. should work till i get my hsg. stormer shipped them today so once they arive i will be putting the 35t back in to start the motor gearing testing all over again. looks like im the only one reg.in the 2009 midwest indoors with a rock force . i hope i can drive it well enough to do this awesome rig justice. ill let you all know how it goes tomorrow night. |
| | #18 |
| Quarry Creeper Join Date: Jan 2008 Location: In the corn
| I'm sporting a RF in Omaha. |
| | #19 |
| | #20 |
| i know ill be the only one with one in my clubs series this year,, |
| Thread Tools | |
| Display Modes | |
