| | #1 |
| Newbie Join Date: Oct 2008 Location: heavener,ok
| I'm geting a rock force in a flew days and was woundering wat motor and esc is working best for u guys and wat gearing........ |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Aug 2008 Location: orlando
| yes i second this i've been looking for a 2.2 i hear great things about the rf but the gearing and wheel speed keep me away |
| | #3 |
| Rock Crawler Join Date: Dec 2007 Location: Dayton, Ohio
| If you look at my build thread I am (currently) using the Mamba Max with a 55T Integy motor. For gearing I am using the stock spur with a 23T pinion and the High Speed gearsets. I am waiting on some other motors to test with this setup and will be reporting back! - David |
| | #4 |
| RCC Addict Join Date: Jul 2007 Location: where the SUPERS Reign SUPREME,,,
| ive been running the goat from novak 21.5t motor system,,with a 81t spur and 23t pinion,,,i have had great results,,my wheel speed is similar to that of mr kingston,,he is running the hs gears though,,i will be installing my hs gears when they come in... |
| | #5 | |
(They called my father Mr Kingston, I am not worthy of that respect) - David | |
| | #6 |
| well ... how is the wheel speed compare to a AX-10 with the novak system? i've looked online and the high speed gears are back ordered everywhere. if i pull the trigger and get a RF, where do i find the gears and the dig set up? |
| | #7 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| stormer has them in stock. |
| | #8 |
| so does the high speed gears help.... I was whating to put an home hobbies 45t motor with the fxr or mamba |
| | #9 |
| i disagree ,,,youve been very helpful to me and others on this site as well as this rig,,im 34 yrs old and feel that the help you give warrants the respect youve earned,,,until you prove me wrong,,you will be given the respect i feel you deserve.. |
| | #10 |
| Ok I ordered the hs gears and dig from stromer hobbies I jest need some add vise for what motor I'm going to run the mamba max I jest need some motor suggestins and gearing ..........,, |
| | #11 |
| i have a 5t puller,a 55t and a 35t. im going to play woth all of them and see which will be the most reliable and the best combo of torque and speed. |
| | #12 | |
- David | |
| | #13 |
| Rock Crawler Join Date: Oct 2006 Location: Germany
| I tried a couple of things to get the right wheelspeed with the right motor. First, I used a 55T Motor and put in some faster gears with a different spur/pinion combo: ![]() The wheelspeed was good but anytime the car gets stuck between to rocks I had a big loss of power. It seems, that the 55turns motor do not have enough watt´s to get through the binding of the wormdrive, that raises when there are loads on it. I then returned to the original gearing and threw in a silver can motor (in black...), I think this one has 23 Turns: ![]() I was surprised how well that worked, the rockforce moved in the speed I wanted and has enough power to get out of the trickiest situations. Also, I had runtimes for over an hour with my racing pack. For me, I will stick to the silver-can and the original gearing. Pete |
| | #14 |
| Quarry Creeper Join Date: May 2005 Location: Crossville,TN
| I am running a Novak Rooster Crawler Brushed ESC with a 55t Integy Lathe motor, high speed gears, and the stock motor gear setup and the performance is great for me right now. Perhaps with more wheel time under my belt with the RockForce I will be trying something else but for now this is a good combo. Carl Last edited by quickster47; 01-10-2009 at 07:03 PM. Reason: English mistake |
| | #15 |
| I wanna be Dave Join Date: Dec 2008 Location: ?
| I have a Tekin RS - Tekin 21.5 with 3s 5000 lipo great tork and ok wheel speed |
| | #16 |
| RCC Addict Join Date: Nov 2008 Location: never been
| Quote: |
| | #17 |
| ^^^ what i said... |
| | #18 |
| | #19 |
| you mentioned your good with your set-up, i am trying to point out how maybe the lower turn motors may be the ticket for the RF besides the high speed gears, proper spur and pinion, forgot to thank you for the help with regards to my querry on gearing, ordered mine based on that. |
| | #20 |
| Newbie Join Date: Dec 2008 Location: Malaysia
| Hmm, I'm using a silver can motor & a Futaba CR230 esc & just switched over to a Tamiya esc of similar spec (actually, the case also looks similar just different stickers !). I find this usable. My friend has a 55t & a higer spec HPI esc in his but I find that setup too slow. Next, I want to put a BL outrunner with 1000kv (HH revolver) & a sidewinder in the rf but I'm waiting for my high speed gear to arrive. Hope this works out. Regards, Joe Ling |
| Thread Tools | |
| Display Modes | |
