| | #1 |
| Pebble Pounder Join Date: Aug 2008 Location: orlando
| is anyone running an after market chassis. i remember seeing a thread on here that any aftermarket chassis would work. Has anyone switched over? or even mod'd there RF chassis, besides a tuber? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| killjoyken is running an swx. have seen one other aftermarket chassis in white delrin. |
| | #3 |
| thanx i look for a link |
| | #4 |
| Rock Crawler Join Date: May 2007 Location: pasadena, tx
| i narrowed my chassis using axial 55mm spacers. project: berg eater! |
| | #5 |
| Pebble Pounder Join Date: Oct 2007 Location: Bay Area
| With 4-link mounts in both the front and rear you can make a aftermarket chassis work. A motor mount will most likely be needed too. Which chassis will depend on your overall desired setup as far as ride height and wheelbase goes. With the 4-link mount position being higher on the axle than other axles out there you may lose some tuning options with squat or anti squat unless you change the overall chassis height. Killjoyken's SWX works well with the modifications he made to the chassis. I'm hoping mine will work as good when it is finally done. |
| | #6 |
| Newbie Join Date: Sep 2008 Location: Udora, Ont.
| i have actually cut my own chasis and converted the front to 4 link. it is still a work in progress and still lots of tweeking to do to get it comp ready and compairable to my tuned axial. |
| Thread Tools | |
| Display Modes | |
