Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: The Rock ROCKS!!!!!!
Old 01-09-2009, 09:23 PM   #1
Default The Rock ROCKS!!!!!!
Click the image to open in full size.Click the image to open in full size.
Well all the parts came in. I running Tekin RS 21.5 Brushless stock gearing
on 3s 5000 maxamps Hitic 9755tg and a Futaba Fasst 2.4 Gh
I think this truck is killer. It do has get tork and pretty fast wheel speed.
saydee1800 is online now   Reply With Quote
Old 01-09-2009, 09:26 PM   #2
TEAM MODERATOR
EeePee's Avatar
You need to fix your rear lockouts, you didn't trim off some material from the rod ends.
That Tekin pretty nice?
EeePee is offline   Reply With Quote
Old 01-09-2009, 09:32 PM   #3
I did cut of any. I was a little nervous. How much did you need to cut and what do I cut them with. ( That is why my rear wheels toe in so much. )
Old 01-09-2009, 10:09 PM   #4
The manual shows you.. I believe it is 2mm per side. Go slow, cut once measure twice, you will be fine!
- David
dkingston is offline   Reply With Quote
Old 01-10-2009, 07:44 AM   #5
- David
so I will need to take of 4mm total. What tool is best to cut this with.
Old 01-10-2009, 08:38 AM   #6
I used my mill to trim my links but you could also use a razor saw with a fine blade. X-Acto makes a great little saw for such purposes.
http://www3.towerhobbies.com/cgi-bin...acto&search=Go
Carl
quickster47 is offline   Reply With Quote
Old 01-10-2009, 08:58 AM   #7
dezmoon's Avatar
i used my dremel with cut off wheel,,,,
dezmoon is offline   Reply With Quote
Old 01-10-2009, 12:42 PM   #8
looks pretty good! i wondered how these really did any complaints?
BEAST02 is offline   Reply With Quote
Old 01-10-2009, 04:52 PM   #9
I used a pair of side cutters. Don't sweat this too much, just snap them off!
- David
Old 01-10-2009, 07:40 PM   #10
- David
i did the same with no issues there is plenty of room for error.
BILLYGOAT is offline   Reply With Quote
Old 01-10-2009, 07:51 PM   #11
how muck is 2 mm in a inch conversion 1/8?
Hey what have you guy found to be the best wheel combo
Old 01-10-2009, 08:01 PM   #12
sparky0068 is offline   Reply With Quote
Old 01-10-2009, 08:46 PM   #13
Page 13 shows a 1:1 image of the piece and how much to cut off. Set your end on the picture and you can see how much you need to cut off.
- David
Old 01-11-2009, 12:10 AM   #14
in this hobby i learned the importance of a caliper...
JOOTZ is offline   Reply With Quote
Old 01-11-2009, 12:13 AM   #15
http://www.worldwidemetric.com/metcal.htm
Old 01-11-2009, 12:21 AM   #16
Originally Posted by sparky0068 View Post
good link
Old 01-11-2009, 07:42 PM   #17
Got some upgrades in the indoor course (my garage) this is my first rock crawler and man Crawling is Great!!!!
[IMG]Click the image to open in full size.[/IMG]
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 01-27-2009, 08:33 PM   #18
Got everything going strong High speed worm gears+dig+ Pro-line Epics with the Chisels I love the Chisel's
Got a new body. I have been run a Tekin 21.5 brushless combo with 3s5000 lipo. When I dig is pluged in the bec over heats I will be putting a Castle bec soon. (don't Tekin RS like all the servo power) here some pics Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 01-27-2009, 10:50 PM   #19
great looking set-up you got there.
Old 01-28-2009, 08:49 AM   #20
How is it climbing for you?
Looks good!
- David
