Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Spur @ pinion
Old 01-12-2009, 04:06 AM   #1
vipxj's Avatar
Default Spur @ pinion
What pitch are the Kyosho pinion and spur gears,are they metric like say tamiya?
cheers
vipxj is offline   Reply With Quote
Old 01-12-2009, 04:51 AM   #2
I believe there was a previous post about this and the conclusion was that they are 48 pitch but metric like the Tamiya stuff. I think that it was also posted that Robinson makes compatible gears.
Carl
quickster47 is offline   Reply With Quote
Old 01-12-2009, 09:40 AM   #3
im using regular 48p spur and pinions. its easier to find and deal with imo
BILLYGOAT is offline   Reply With Quote
Old 01-12-2009, 10:11 AM   #4
Yup. They posted 48p of Robinson racing pinions and kimbruogh spurs will do.
4wdmt is offline   Reply With Quote
Old 01-12-2009, 10:22 AM   #5
no they're regular 48p stuff.
goobs is offline   Reply With Quote
Old 01-12-2009, 01:28 PM   #6
Pure Pwnage
dave56bug's Avatar
Tamiya uses both regular 48p gears and metric depending on the kit, anyway, Kyosho uses regular 48p pinions ans spurs, kimbrough, robinson, AE, Duratrax, Kyosho and more make pinions and spurs that will work fine.
dave56bug is offline   Reply With Quote
Old 01-12-2009, 05:40 PM   #7
vipxj's Avatar
Cheers guys,i tried tamiya metric pinions seem to be a slightly different pitch! havent powered up motor though.
Ill have to find some kyosho pinions.
