| | #1 |
| Newbie Join Date: Jan 2009 Location: Des Moines
| Hello there! Got the RF built and have it running with the DIG 3 position switch in the flaps.... Its really fun by the way! The only problem I have is that I need to phyically move the stick to center and hold it there for a second before I can go in reverse. I would like to be able to use my right stick for forward and reverse as well as turning. Does anyone know what to do in this situation? I'm using a Mamba Max ESC...is there a programing area where I can change the time it takes to recognize zero position? Thanks for the help Jimbo |
| Sponsored Links | |
| | #2 | |
| Rock Crawler Join Date: Dec 2007 Location: Dayton, Ohio
Proportional w/ Reverse Lockout For bashing or racing (may not be an allowed setting for racing). The controller must see 2 seconds of steady neutral throttle before it will allow reverse operation. Change that to Forward to Brake To Reverse. That should fix it. - David | |
| | #3 |
| Thanks David, that worked great. By chance, is there anyway to rig it with the right (elevator) stick throttle? I won't be doing it, just wondering if its possible. Thanks again |
| | #4 |
| Gavyn is my BFFL ![]() Join Date: Feb 2007 Location: hunting pandas
| plug the esc into the elevator slot on the reciever and recalibrate |
| | #5 |
| I was thinking maybe I would try that, but I thought that the "power" had to be in the throttle channel. Thanks! By the way, maybe I can get another answer: How can I set up the dig with a DX3 with 3 positions? Thanks again Jimmy |
| | #6 | |
I am not sure about setting up the dig on the DX3 since I haven't played with one. Maybe someone else who has one can chime in! - David | |
| | #7 |
| RCC Addict Join Date: Apr 2007 Location: RAMBLIN
| is it a dx3.0 or dx3r? |
| | #8 |
| Its a DX3.0 Thanks Billygoat! Jimmy |
| | #9 |
| looks like 2p is your only option. looks like grip switch c is a good option for a 2p(4wd and dig no freewheel). |
| | #10 |
| Thanks for the info! jimmy |
| Thread Tools | |
| Display Modes | |
