Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: radios
Old 01-21-2009, 03:58 AM   #1
vipxj's Avatar
Default radios
HEY GUYS,
What radios is everybody using for DIG,im going to use my dx6i and wondering what channel or switchs to use?
Any idea?
My dig has finally turned up,now juet the high speed gears.:-(
cheers.
vipxj is offline   Reply With Quote
Old 01-21-2009, 09:16 AM   #2
on the dx6i just use a 3p switch. its pretty easy to get it tuned up. just set your center position to freewheel. and then set your epa's fro dig or 4wd. do the fuel tubing mod instead or in adition to the springs. it will save your servo. also dont forget lots of grease . it was the key to making mine smooth after break in. hope that helped.
oh and i run a dx3r
BILLYGOAT is offline   Reply With Quote
Old 01-21-2009, 11:40 AM   #3
vipxj's Avatar
Cheers billygoat, i should read the manual really.Im one of those that read the book afterwards.
I better go play with some switchs then!
Old 01-22-2009, 10:45 AM   #4
vipxj's Avatar
Ah ,it doesnt have a 3 possition switch,so ill have to use a gimbel(stick?),
Anybody else got any ideas??????????????????
cheers.
Old 01-22-2009, 11:40 AM   #5
I run a Futaba 3PM. I have it set up for 3 position 3rd channel. It works well with the RF dig.
HiloDB1 is offline   Reply With Quote
Old 01-22-2009, 12:10 PM   #6
heres a link for you to read. DX6 - DIG Setup for VF DIG
Old 01-23-2009, 04:21 AM   #7
vipxj's Avatar
Cheers again billygoat,your the man!
