Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: How are your shocks?
Old 01-26-2009, 11:57 AM   #1
Default How are your shocks?
Hi guys. Just a general question. How smooth are your oil shocks? I am playing around with mine and I feel that they are a bit squeashy or shall I say stiicky?. I tried my best to build them with no air bubbles inside and really full of oil, but somehow...there is a little squeaking sound when you compress them. Is this normal?
Thanks.
4wdmt is offline   Reply With Quote
Old 01-26-2009, 12:10 PM   #2
mine are very smooth. i didnt file like the manual siad. i drilled 1/16" hotes in all my pistons and am running 40wt oil in all my shocks. no squeeks though. is it the spring cup or something outside?
BILLYGOAT is offline   Reply With Quote
Old 01-26-2009, 12:18 PM   #3
It kinda sounds like you have some air bubbles in the shocks. That "squishing" noise is usually the bubbles passing past the piston.
How I build mine:
- I filled the shock half way then cycled the piston a couple of times to get the air our from under the piston.
- then fill the shock until it is 1/8 from the top.
- Slowly push the piston up 1/4 inch
- Place the bladder on top of the shock.
- Carefully pull the piston down creating a slight vacuum on the bladder then put the cap on.
You might try taking the cap off, letting them sit for a while. Then lightly "flick" the shock body to coax the air bubbles up. Reseal and go.
- David
dkingston is offline   Reply With Quote
Old 01-26-2009, 12:21 PM   #4
how many holes in each
saydee1800 is online now   Reply With Quote
Old 01-26-2009, 12:57 PM   #5
i only drilled 1 hole in each piston. also i followed Davids instructions as well. have had no issues even after i took them apart and limited the rear for my new chassis.
Old 01-26-2009, 04:01 PM   #6
have 30wt on the shocks and shaved as per the book, no squishing sounds. ive been toying with putting the t-maxx stock springs on there since i still have them from swapping to big bores on the old truck and see how it goes. unless somebody has done it and save me some time
JOOTZ is offline   Reply With Quote
Old 01-26-2009, 04:07 PM   #7
living the life
jl_907's Avatar
Mine are very smooth, I also drill and extra hole in my pistons, but I went with 30wt oil.
jl_907 is offline   Reply With Quote
Old 01-26-2009, 07:03 PM   #8
Thanks guys. Its builder error. Took the caps off and found some tiny air bubbles. I guess I am in a hurry to finish them. Wish I sis the drill a hole mod instead of shaving. Anyways, it is all good. They are now smooth and no noise.
David, the tip is helpful.
Old 01-27-2009, 07:46 PM   #9
^^^ good to know you got the shock issue handled.
