Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Weigh-In
Old 01-27-2009, 03:37 PM   #1
Default Weigh-In
So how much does your rig weigh? Give the battery, motor, and any wheel weights you use. Thanks. I'm considering a RF but I may wait for the losi b/c it weighs in at 4.5lbs and I prefer the feather weight class
mulepic is offline   Reply With Quote
Old 01-27-2009, 03:50 PM   #2
mine is a tank and I like it that way
just get the plastic losi
saydee1800 is online now   Reply With Quote
Old 01-27-2009, 04:18 PM   #3
the losi will require more weight in the wheels to be comp ready.
mine was a tank until i went with the DNA chassis. ill weigh it tonight and let you know i believe ite in the 6.5 to 7 lbs range with weight in the tires. the losi is a good option but not any less expensive than the rf and i believe the rf is more durrable out of the box. we shall see.
BILLYGOAT is offline   Reply With Quote
Old 01-27-2009, 04:28 PM   #4
Thanks, I'll look forward to the responses. I sort of suspected it would be the berg weight category.
Old 01-27-2009, 04:37 PM   #5
Mine is weighing 2.26kg. Stock with HS gears, Novak Super Duty ESC, Futaba servo, AM receiver and Venom motor. No weights on wheels and No batteries when I checked the weight.
4wdmt is offline   Reply With Quote
Old 01-27-2009, 04:58 PM   #6
dezmoon's Avatar
mines about 5.5lbs
dezmoon is offline   Reply With Quote
Old 01-27-2009, 05:01 PM   #7
Originally Posted by dezmoon View Post
mines about 5.5lbs
2.2 kg = 4.8 lbs, that's actually a lot lighter than I thought they would be.
Old 01-27-2009, 05:50 PM   #8
mine is 2.64kg with 6oz in each front wheel and 3oz in each rear. so that's 5.82 lb's
spinner is offline   Reply With Quote
Old 01-27-2009, 05:54 PM   #9
im not sure of the total weight but im running a lipo and a custom chasis, 10oz in each front wheel with another 9oz on the front axle, and 5oz in the rear wheels. im using the proline epic wheels.
Rc_Cam is offline   Reply With Quote
