Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Want to run 4 link up front?
Old 01-29-2009, 11:08 AM   #1
Pure Pwnage
dave56bug's Avatar
Default Want to run 4 link up front?
I found this, too bad its blue. But it'll do the job. They also make machine knuckles and some other parts.
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=58352
dave56bug is offline   Reply With Quote
Old 01-29-2009, 11:31 AM   #2
looks good except hotracings notoriety for bad fitment.
JOOTZ is offline   Reply With Quote
Old 01-29-2009, 11:58 AM   #3
hot racing sucks but it looks like it would do the job. its easy enough to take the ano off
BILLYGOAT is offline   Reply With Quote
Old 01-29-2009, 12:22 PM   #4
It says rear. From the looks of it the 2nd hole will be going forward not into the center of the truck where you need it when mounted on the front. At least the axle mounting portion would be done for you.
Dewmerz is offline   Reply With Quote
Old 01-29-2009, 12:31 PM   #5
its like the stock rear. it looks reversable to me . with it being a 2 piece. i like ours better
just looked again maybe notbut it would take up that 1/4" i shortened my toplinks to corect clocking.
Old 01-29-2009, 12:51 PM   #6
You can get another rear and put it on the front. The whole tree that it comes on is like $8? (I will look for the part number and post later)
I have one and tested, it fits by putting it on the backside of the axle and running the screws into it. Only problem, upper mound on the motor side comes in contact with the motor... it IS possible to do very cheaply if you tilt the motor and spur up some.
- David
dkingston is offline   Reply With Quote
Old 01-29-2009, 01:15 PM   #7
Pure Pwnage
dave56bug's Avatar
I don't know about poor fitment, I have a number of Hot Racing items on my Axial and i'm happy with them. Similar to Integy, where certain parts are poor quality ripoffs and certain items are really nice for the price. That said I haven't and likely wont purchase this 4link piece, just linking it for those who might be interested in using an aftermarket chassis.
I have seen that the Kyosho rear 4 link piece will work as well for 4 link in front.
Old 01-29-2009, 01:17 PM   #8
I think it is RF003 is the part number
XTREME RACING is offline   Reply With Quote
Old 01-29-2009, 01:20 PM   #9
Pure Pwnage
dave56bug's Avatar
Ok fine, I give in lol, get the Kyosho piece for $5.95!
https://www.ssl-stormerhobbies.com/c...ns&pn=KYORF003
:-P
Old 01-29-2009, 01:34 PM   #10
and I believe that is the whole tree of parts including some rod ends and the panhard mount?
- David
Old 01-29-2009, 02:38 PM   #11
- David
I don't remember it having rod ends but it does have the front/rear mount and the pieces for the center trans/spur gear mount.
Old 01-29-2009, 03:11 PM   #12
could be, I just don't remember!
- David
Old 01-29-2009, 05:14 PM   #13
still for the price it aint bad, OEM kyosho to boot.
Old 01-29-2009, 08:18 PM   #14
it is reversible thats what i did
goobs is online now   Reply With Quote
