Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Rock Force
Thread: Problem with my Rock Force
Old 02-09-2009, 09:07 PM   #1
Default Problem with my Rock Force
Once I put the high speed worm gears in I have a tot of play in the wheels and my motor gets hot I have motor problems
do you know why?
saydee1800 is offline   Reply With Quote
Old 02-09-2009, 10:01 PM   #2
YGPM
- David
dkingston is offline   Reply With Quote
Old 02-09-2009, 10:39 PM   #3
TEAM MODERATOR
EeePee's Avatar
Originally Posted by dkingston View Post
YGPM
What's the secret?
EeePee is online now   Reply With Quote
Old 02-10-2009, 07:42 AM   #4
Originally Posted by EeePee View Post
What's the secret?
No secret, he just pm'd me the same message that he posted here. I just inquired more information about his setup, then I saw his post here!
If I have any advice for him I will post it here.
- David
Old 02-10-2009, 09:10 AM   #5
- David
I found that the set screw on the worm gear was loose in the front. In the back are you not to reinstall the set screw I have it set with out when I put the dig in
Old 02-10-2009, 09:12 AM   #6
put the set screw back in there bro.
JOOTZ is offline   Reply With Quote
Old 02-10-2009, 09:30 AM   #7
even in the back?
they dont show that in the manual
Old 02-10-2009, 10:06 AM   #8
Originally Posted by saydee1800 View Post
even in the back?
You do not replace the set screw in the ring gear when you put the dig in.
Glad you found your problem! (especially before it ruined a comp by coming out!)
- David
Old 02-10-2009, 10:39 AM   #9
- David
well I hope I found my problem
so David NO set screw in the back with the dig right?
Old 02-10-2009, 12:09 PM   #10
Pure Pwnage
dave56bug's Avatar
Correct, NO set screw in back, Wrong David I know, :-P
dave56bug is offline   Reply With Quote
Old 02-10-2009, 12:16 PM   #11
Old 02-10-2009, 03:28 PM   #12
looks like i gotta go in there again, shoulda followed the book to the finish-dang.
