Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Twin/Mad force
Thread: Just another Twin
Old 07-17-2005, 02:11 PM   #1
Default Just another Twin
It's not 100% finished but close enough to go have fun. In Lexus IS300 trim :
krawlr is offline   Reply With Quote
Old 07-17-2005, 02:31 PM   #2
2006 2.2 National Champ
BENDER's Avatar
Nice work, looks burly as hell!!
Got any more pics of your suspension set-up?
BENDER is offline   Reply With Quote
Old 07-17-2005, 02:31 PM   #3
A stick style chassis concept with a torsion bar suspension? How does it work, performance wise? I have actually been thinking of "sticking" the back end of my maxx for a while now.
boxedjuice87 is offline   Reply With Quote
Old 07-17-2005, 03:51 PM   #4
I think it's working pretty good so far. I'll have to get some vid and see what ya think. The hiem on top of the axle is mounted rigid with swaybars connecting the lower links, that's it. I may put a shock on each end but it just doesn't seem to need it. :?
Here's a couple underside pics.:
Old 07-17-2005, 05:39 PM   #5
This reminds me of something
Check This post out
http://www.rccrawler.com/forum/showt...799#post120799
Brute_Crawler is offline   Reply With Quote
Old 07-17-2005, 08:18 PM   #6
Here's a little bit of vid. My front diff lock method failed and the rear servo stripped the gears and started doing it's own thing near the end.
http://www.krawlr.com/video/cyclops2.wmv
Waiting on an index table to finish my beadlocks and try making spools. It will get pulled back apart and the frame will get trimmed and lightened to lower the C/G.
Old 07-17-2005, 08:31 PM   #7
Looks great,but whats the clicking noise?Is that the chain slipping?
WestCoastPJ is offline   Reply With Quote
Old 07-17-2005, 09:28 PM   #8
Nope that is a servo.I dont think you will ever hurt that chain mine was put thru hell many times and I never had trouble out of it.
syco133 is offline   Reply With Quote
Old 07-17-2005, 09:32 PM   #9
That was the rear servo dieing near the end, gears are trashed. It was the one I originally got with the truck and I didn't really expect it to last too long. You can also hear my thumb slipping off the steering control a few times.
Old 07-17-2005, 10:01 PM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
its a NVT (no vertical travel) shafty! awesome, and beefy! the twin axles are my favorite yet.
JohnRobHolmes is offline   Reply With Quote
Old 07-19-2005, 08:41 PM   #11
That's a cool crawler. How did you get the revo shafts to fit the axle input shafts? I'm working on a twin crawler too, that's why I ask.
mnstrbetle is offline   Reply With Quote
Old 07-19-2005, 11:51 PM   #12
drill it out.
Old 07-20-2005, 10:18 AM   #13
I made my own adapters but drilling them seems to be working well for others. If you look close, you can see I haven't figured out how to drill that pin hole accurately with my equipment.
Old 07-20-2005, 10:45 AM   #14
Originally Posted by johnrobholmes
drill it out.
Wow man, thanks for the in depth answer. I can see that you really put alot of time and thought into it! Your a friggin genious!
Old 07-20-2005, 10:49 AM   #15
Krawlr...thank you very much for your reply. I could see that it looked as though there was something a little extra involved in the way you coupled your drive shafts. That's a very interesting and inovative way of assembling your drive shafts onto the axles...obviously a little more involved than just 'drilling them out'.
Have you had any problems with your driveshaft adapters during testing your rig?
Old 07-20-2005, 12:01 PM   #16
I was worried about the loose fit of the pin hole but I see no damage to the Revo end with it back apart. So far so good. :neutral:
Old 07-20-2005, 12:22 PM   #17
you did use a center punch to keep the bit from wandering right?
moonbuggy is offline   Reply With Quote
Old 07-20-2005, 12:39 PM   #18
i just drilled mine out, with some really odd size bit that was close to 8mm. thats all, and they are working just fine. then i drilled the pinion with a bit that was close to the revo pin size. its working good too. i used a center punch and a hand drill. is this better?
Old 07-20-2005, 01:56 PM   #19
Yea I used a transfer punch/center drill but I don't have a good way to hold them good and square on my machine yet. I've had an index table on order for a few weeks now. I couldn't stand waiting anymore. I have beadlocks waiting on it to be drilled too.
Old 07-21-2005, 10:51 AM   #20
Smile
lol, much better man! Thanks
