| | #1 |
| Rock Crawler Join Date: Jul 2004 Location: Rexburg
| Which would be better for a 1/6 scale crawler? Is one stronger than the other, or are they 'bout the same? |
| Sponsored Links | |
| | #2 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| I'd say go for TF axles |
| | #3 |
| Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
| XF axles wider, stronger, better |
| | #4 | |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| I've never run X-factor axles but I know they are strong enough for Kongs and a great deal of abuse,so yeah they'd work. I myself run Twin axles with upgraded helical cut steel ring and pinions. I've been locked solid and spinning Kongs since they came out of the box and have yet to brake anything. I'd vote for Twin axles but I'm a bit biased. Honestly,either one will work,which ever one is easier to get and cheaper for ya would be my deciding factor. Quote:
Stronger,how do you know this? Better,in your opinion maybe :-P In this picture,my slightly modded Twin axles are 14" wide hex to hex,if I'm not mistaken X axles are 14" hex to hex | |
| | #5 | |
Wider in stock form stronger: ive ran both, XF axles have a burly steel ring/pinion right out of the box TF's dont but kyosho does make some...more $. TF,s have dogbones in the axles, XF's have nice shafts that clamp onto the diff outputs. XF's better in my opinion. and cheaper in the long run | |
| | #6 | |
| Well,I understand your points and can see where you feel X axles are better. I still feel Twin axles are better. I'm not trying to argue with you or prove you wrong,I've got my opinion and you've got yours and it's all cool Quote:
The helical cut gears ARE stronger than the straight cut gears,hands down. How many vehicles do you know that run a staight cut ring and pinion? Helical cut gears are more efficient,quieter,and stronger because they have a better gear mesh with alot more contact patch. Again,not trying to argue,just stating my opinion. | |
| | #7 | |
| Rock Crawler ![]() Join Date: Jan 2004 Location: chicago
with the kyosho axles you can use 1/8 buggy diffs in them right? and you have the option of narrowing the axle, and imo they just look a heck of alot cleaner. i like the xfactor axles and i wouldnt tell somebody not to use them, but if i was building another big shafty rig i wouldnt hesitate to try the kyoshos. | |
| | #8 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| I would vote twin axles because of the softer plastic. It just doesnt break under impact like tamiya plastic. Yes the stock aluminum diff ring and pinion is crap, but they make hardened steel aftermarket stuff. Also, the twin takes buggy diffs as stated, and accepts Savage outdrives. Over all, both will need some some work for a crawler, but IMO the twin axles build up stouter. |
| | #9 |
| Ya know,I was just thinking,the aluminum ring and pinion are very weak. If you shim them up a little tighter they are pretty reliable though. My son is rougher on his Twin than I am on mine,he's bad for full throttle assults on near impossable obsticles. He is still running the stock gears locked solid spinning LST tires and has yet to hear the first pop. All we did was install a few shims to make the pinion gear mesh up tighter with the ring gear. You can get Kyosho shim packs for about 2 or 3 bucks. From what I've seen with his gears I probly could have gotten by with the factory gears running my Kongs if I would have shimmed them up tighter. |
| | #10 | |
| | #11 | |
| Quarry Creeper Join Date: May 2005 Location: lost in vintage tamiya land.
| | #12 | |
| Pebble Pounder Join Date: Oct 2004 Location: Colorado
See: http://www.automation.com/sitepages/pid1906.php Last edited by BultacoJim; 10-08-2005 at 03:43 PM. | |
| | #13 |
| Thanks for all the help guys, but i think i am not going to do this project. Im saving up for the 1/5 HPI buggy! |
| | #14 |
| 1 man, 2 sons ![]() Join Date: Aug 2005 Location: Recovering@ the hobby garage MT.
| kyosho makes the TF axles, do they also make the x-factor or is that another manufacture? |
| | #15 | |
kyosho - twin force XTM - x-factor found it. search is nice. | |
| Thread Tools | |
| Display Modes | |
