Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Twin/Mad force
Thread: i need twin force inside diameter of axle tube
Old 10-02-2004, 11:25 AM   #1
Default i need twin force inside diameter of axle tube
if some one has there twin force apart i could use the inside diameter i am looking for 12mm that is the magic number. thanks
jtothec is offline   Reply With Quote
Old 10-03-2004, 01:03 AM   #2
TEAM MODERATOR
Reflection's Avatar
Default Re: i need twin force inside diameter of axle tube
I don't have mine apart and don't know exactly what it measures. I do know though,it's alot bigger than 12mm. The outside diameter is just a shade less than 1" with a wall thickness less than 1/8".
Thinking of custom steel or aluminum tubes?
I'm gonna have a set machined (sp) out for me as soon as my freind has the time to fool with it. I'm gonna see if he can angle the tubes a little also for more ground clearence.
Reflection is offline   Reply With Quote
Old 10-03-2004, 10:47 AM   #3
thanks for the info that helps out alot
