Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Kyosho Twin/Mad force
Like Tree1Likes
Thread: I know its wrong, but it feels so right!!
Old 04-07-2012, 09:31 PM   #21
Puller Power!!!
Farmer's Avatar
Default Re: I know its wrong, but it feels so right!!
Holly shit that is insane
Later,
Farmer
Farmer is offline   Reply With Quote
Old 04-08-2012, 12:19 AM   #22
Gittin it .....fully
BLKXJ 96's Avatar
Looks awesome Lee!!
BLKXJ 96 is online now   Reply With Quote
Old 04-08-2012, 10:20 AM   #23
mjderstine's Avatar
Originally Posted by v84x4 View Post
I'm running the same setup in my BYB (1900KV RX8 On 6S)
And well...........You have seen the video
I had to gear it down at the Pinion to a 17T
And I'm running 3.3:1 Axial Ratio Ring & Pinion
and now am getting 38MPH (much More Controllable)
I cant remember if you have the 4.3:1 or 3.3:1 ring & pinion axial setup
But.....
I will tell you if you have the 4.3:1 R & P setup like "Cordwood" has in his FOFF
Your in for around 53MPH using 6 inch Tires, a 21T pinion and the 56T RR Slipper
Cant wait for ECC
Regards Big Rick
dont you mean axle setup
mjderstine is offline   Reply With Quote
Old 04-08-2012, 10:28 AM   #24
www.supershafty.com
v84x4's Avatar
That's funny
I was packaging up some "AXIAL" product up for shipping when I wrote that so I guess I had Axial on the brain
v84x4 is offline   Reply With Quote
Old 04-08-2012, 12:42 PM   #25
mjderstine's Avatar
yeah man you did!!
least its a shafty on the brain!
Old 04-10-2012, 04:37 AM   #26
Fat guy gonna try G6'n!
The Real Dogman's Avatar
Small update:
Got the cms kit last night and immediately put it on with the servo to get my drag link length so I can sort out the panhard link and mount. This is where the fun begins because as soon as that's finished I will get some power to this beast and see what needs to fixed before ECC!
I also opened the scoop on the dinky hood to get air flow over the esc fan, looks cool looking at the front and thru the scoop you see the rx8 logo. Will get some pics later...
The Real Dogman is offline   Reply With Quote
Old 04-11-2012, 10:58 PM   #27
OK guys a few pics!! Woohoo
The front suspension is sorted and now I am ready to finish the elects and maybe do a test run this weekend!
Love this view, POWER!!
Think this will work!!
Think I got the Panhard bar in the right spot!! cant wait to get this thing powered up and throwing roosts!!
Def diggin the stance on this ride!!
And it look like we got that the gravity thing is well handled. This is going to be a well handling and stable hot rod!!
Got Beef?? Love the tranny Rick!! Thanks buddy!!
Drive line should Take it!!
Great view too, feel kinda dirty looking at it..
Speed Controller and RX mounted to custom acrylic plate. ESC is screwed to plate. Didn't think servo tape was gonna hold it down well enough once this beast starts its beat down on planet earth,, lol
Its hard to see in this pic but if you look close you can see the custom cut 1/4" plate under the trans to raise the motor up high enough to clear the upper link mount under the motor end.
And finally a full compression shot of the panhard link. I couldn't be more happy with it if I hadn't built it myself!! Flat 16 gauge sheet, bent, hammered, drilled and filed to create the mount and it only took me about 45 minutes!! Perfect!!
Too bad about the crappy iPhone Pics!! lol
Until next time guys!! hopefully I will have a video by then!!
I'm tired, gonna go crawl in to bed next to my wife 'night guys!
C-ya!!
Old 04-12-2012, 07:25 AM   #28
mjderstine's Avatar
looks awesome man. that's gonna be a sweet rig out there!
so, i know you are only using an iphone, but can you get a closer pic of the panhard mount. i have seen how Bart has made them from the stock control arms, but i cant see how you incorporated the metal into it? did you just bend it around the control arm stub that you have there?
EDIT: actually i think i see now, you just kinda made a u channel and bolted that to the axle, and arent using any of the stock control arm protrusion at all.
Old 04-12-2012, 09:20 AM   #29
You got it mj that's exactly what I did
Old 04-12-2012, 10:20 AM   #30
BHS, it's all Iowa's got.
Bart bender's Avatar
Is it me or dose this thing need some paddle tires Looks good
Bart bender is offline   Reply With Quote
Old 04-16-2012, 12:47 PM   #31
Micro-update,
We Have Power!! Ran it for a few minutes yesterday on a 2 cell 5000mAh battery I have for one of my short course trucks. No so impressive unless the ECS is not in the correct mode. I will be checking that out tonight. But it have power and moves under its own juice. My LHS has 2 3s 65c 2200mAh batteries coming in for me on wednesday. Then we will see how much fun that will be!!
Old 04-19-2012, 09:34 AM   #32
go 4s
792.5cj5 is offline   Reply With Quote
Old 05-22-2012, 07:34 PM   #33
that thing is sick, we need a vid once its done!!
Kylar is offline   Reply With Quote
Old 05-23-2012, 04:38 AM   #34
Originally Posted by 792.5cj5 View Post
go 4s
Seconded. I just bought a Summit with a 1900kv setup in it... I ran it on twin 2s (to get 4s in total) and its totally insane. The tyres try to rip themselves off the rims and it can't get to top speed without getting out of control!
6s would be OTT but depends on how much is too much lol
simon170 is offline   Reply With Quote
Old 05-23-2012, 05:33 AM   #35
www.supershafty.com
v84x4's Avatar
I have driven it on 6s and it's just uncontrollable
It only weighs 6.9 lbs so its too light
Wicked fun
We will get some video up after "Battle grounds"
Regards Rick
Old 05-23-2012, 08:55 PM   #36
Puller Power!!!
Farmer's Avatar
Can I drive it??????
Later,
Farmer
Old 05-24-2012, 05:46 AM   #37
www.supershafty.com
v84x4's Avatar
Later,
Farmer
Sure but you will have to wear "Ankle & Shin Guards"
Regards rick
Old 05-24-2012, 07:04 AM   #38
mjderstine's Avatar
wtf man! did you do that last night after your wine and vodka?!
Old 05-24-2012, 07:19 AM   #39
Holy crap! That's taken a proper bite out of you!!
Disclamer: SuperShafty rides can be dangerous when unleashed
I know its wrong, but it feels so right!! - Similar Threads
So this is how it feels... GraTou Chit Chat 0 01-20-2007 04:00 PM
who else feels this way badtodabone Chit Chat 8 10-25-2005 12:56 PM
Feels like Xmas here! jason Chit Chat 12 03-13-2005 04:05 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
