09-17-2013, 03:40 PM | #41 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: sportsman twin force
The bottom three screws are not needed so you can put the pumpkin on a bench grinder and smooth out the bottom if you haven't already sir |
09-17-2013, 06:03 PM | #42 | ||
RCC Addict Join Date: Nov 2006 Location: burlington
| Re: sportsman twin force thanks thanks bud i almost went with steel reserve. Quote:
thanks guys. will probably do a combination of both ideas. | ||
09-17-2013, 08:49 PM | #43 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
hey look at us all helping out. carefule or one of us might take credit for the whole thing.
09-19-2013, 01:14 AM | #44 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
yay bud. good work bro. very nice job man |
09-29-2013, 01:23 PM | #45 |
Can we ask for a total weight on this truck please Regards Rick |
09-29-2013, 06:32 PM | #46 | |
| Re: sportsman twin force Quote:
thanks man. will have to get a scale to do that's. | |
09-29-2013, 06:59 PM | #47 |
made the shafts today. for the fronts, mark where the shafts will pivot. then cut them down to that length. I sleeve them with stainless tube when I weld them back together. you can get the right length dog bones for the rear. but the pin is to small for my liking. to much slop in the drive cups. so I just cut and sleeve some with bigger pins. finally on its own feet. |
09-29-2013, 07:58 PM | #48 |
Looks great man. If you want to get of more slop out of the rear you could always put universals there too. |
09-29-2013, 11:54 PM | #49 | |
so here is the weight of it right know. this is going to go up with the SLW's and battery. got some VooDoo's. four silvers and two blues. got these from Diablo666 in the for sale section. just waiting for another pair to pop up so i can mount the tires. | |
09-30-2013, 08:00 AM | #50 |
that's pretty lightweight man. should make a killer shafty!
10-22-2013, 07:03 PM | #51 |
| Re: sportsman twin force |
10-23-2013, 07:18 AM | #52 |
just a tip. when allowing the knuckles to turn more make sure that the CVD is not now hitting the inside of the knuckle on full steering. i have found that they usually hit before you bottom out on the C-hub after you do the grinding. know what i mean? i can take a picture tonight. |
10-23-2013, 09:31 AM | #53 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
Flip the servo horn and put the tie rod on top of the knuckles. Could even use the closer hole on the horn and trim it down.
10-23-2013, 12:21 PM | #54 |
yeah man. what bart said. i put my tierods as close in as i can get. that way i dont need that long arm on the servo. you might be able to tell what i did in these pics with the tie rods. the drag link id on the end hole, but the control arm from the servo is very close in. that makes the servo hve to move very small amounts, and also speeds up the action a bunch. the bottom picture you can see what i was doing. |
10-24-2013, 02:10 PM | #55 | |
thanks bud. i did run into that problem, so i shaved some material out, inside the knuckles. | |
10-24-2013, 02:21 PM | #56 | ||
this is what i ended up with. to make it work i put some spacers in the servo to move it back. so the tie rod wouldnt hit the servo horn at full turn. | ||
10-24-2013, 03:37 PM | #57 |
10-24-2013, 06:21 PM | #58 |
yup, you know what you're doing! nice and clean on that linkage setup now.
10-26-2013, 09:52 PM | #59 |
10-27-2013, 07:11 AM | #60 |
Its so Sick If I send you all the parts will you build me one? Regards Rick |
Tags |
#ayalametalworks, #crawlerinnovations |
sportsman twin force - Similar Threads | ||||
Difference between X-factor, Twin Force and Mad Force axles | Flatty | XTM Crawler | 1 | 09-11-2008 05:48 PM |
Is the Mad Force interchangable with Twin Force part | Trac95ker | Kyosho Crawlers | 2 | 04-12-2005 12:11 AM |
