02-01-2014, 03:22 PM | #41 |
| Re: Forced Wraith
Nice! I was reading and saw the wheel issue and was gonna suggest those wheels! Looking good dude!
02-03-2014, 09:09 AM | #42 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Here's the wheels with a custom set of Rock Beast 2's and a custom set of Deuce's Wild Foams: Making progress on the build :-) . Sent from the lab @ the CI compound | |
02-03-2014, 09:44 AM | #43 |
| Re: Forced Wraith
What's custom bout dem dar tars man, just the inner bead?
02-03-2014, 10:09 AM | #44 |
| Re: Forced Wraith Correct. 2.2 / 3.0 Pitbull Rock Beast 2 tire with a custom Deuce's Wild 2.2 Tall foam modified to the fit the 2.2 / 3.0 bead lock. Because it's an RC4WD bead lock wheel, the tires MUST be GLUED to the rims NO MATTER WHAT. It's a 3 piece design bead lock, but the center section is not wide enough to properly clamp any brand tires to the wheel RC3WD has discontinued the wheel for obvious reasons, but I was lucky enough to get these in a on going purchase of Shelby's RC lot. |
02-03-2014, 10:35 AM | #45 |
| Re: Forced Wraith
ooo. I didn't know those were the 2.2/3.0 setup. Those are a perfect fit for those axles.
02-07-2014, 09:26 PM | #46 |
Progress... Went back to an 6mm CI short trans output to fit a revo rear drive shaft: Front servo and linkage installed: Rear servo and linkage installed: New RX: New motor: Sent from the lab @ the CI compound |
02-08-2014, 09:53 AM | #47 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
| Re: Forced Wraith
Wow, didn't realize those Falsenfest knuckles were that big. The stock knuckles fit right into a 2.2.
02-08-2014, 11:21 AM | #48 |
Wired up; ready for interior: Everything has been soaked in: Interior in: Custom Cage by Carter Fab: Sent from the lab @ the CI compound |
06-02-2014, 08:10 AM | #49 |
| Re: Forced Wraith I did not realize how far behind I am on this build thread. The Forced Wraith has been completed for some time now. I'll post updated pictures later. My son & I brought this rig to the ETXRCC Get Together at Barnwell Mountain ORV Park this weekend. Here's a short video of it on the rock garden at Barnwell. |
06-02-2014, 08:40 AM | #50 |
| Re: Forced Wraith
Awesome, looks like it is working good.
06-02-2014, 12:59 PM | #51 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: Forced Wraith
lookin real good on those rocks. nicely done. how much does the rig weigh in the end?
06-06-2014, 04:02 PM | #52 |
| Re: Forced Wraith Thank you sir. We really enjoy this rig a lot! Thank you once again for starting this project for me Thank you sir. RTR weight as filmed was 9 pounds 11 ounces |
06-06-2014, 04:04 PM | #53 |
| Re: Forced Wraith Our local club, ETXRCC had a Get Together @ Barnwell Mountain ORV Park in Gilmer, Texas last weekend. It was an evening get together. We decided to stay the night ahead of time in order to test and record the following morning. Here is a collection of footage from that test and tune. The Forced Wraith had 7 battery packs through it for the weekend. |
06-06-2014, 04:17 PM | #54 |
| Re: Forced Wraith
Glad to see three rigs I help build still going strong, yota, big blue and this one!
06-21-2014, 11:18 AM | #55 |
I've had one of these CFM steel hoods for a very long time now. It was time to use it. I fitted it to the Forced Wraith. Here are some current pictures before the hood and panels are removed for paint: ..Uploaded from the lab @ the C.I. Compound... |
06-21-2014, 11:19 AM | #56 |
08-08-2014, 05:34 PM | #57 |
| Re: Forced Wraith
Several G6's later and lots of playing time and it broke its first part tonight: I'm thinking universals are the fix over the HPI CVD. The back beads are coming off. |
08-08-2014, 06:38 PM | #58 |
| Re: Forced Wraith
Something rubbing that bead?
08-08-2014, 09:15 PM | #59 |
| Re: Forced Wraith
yeah man. i have been using kyosho of ofna universals on all my TF axles for years and have never had a failure. do it!
10-31-2014, 10:10 AM | #60 |
| Re: Forced Wraith No. The bead locks do not hold at all for the most part. I have the tires CA glued to the rims and sometimes the rear pulls out. This is my first Twin Force build and I'm learning quickly thanks to the information on RCC. I replaced the CVD with a Universal and it's good to go. |
Forced Wraith - Similar Threads | ||||
First Forced Upgrade! :( | Scurvy | Axial Wraith | 29 | 03-22-2012 05:37 PM |
Forced Articulation (3P)? | Access | Electronics | 6 | 10-22-2008 05:08 PM |
Forced articulation leagality | Kamikaze | WRCCA Rules | 20 | 12-06-2006 04:18 PM |
Forced Artic | Rikpal | General Crawlers | 13 | 10-12-2006 04:45 PM |
