03-11-2014, 02:21 PM | #1 |
Newbie Join Date: Aug 2012 Location: Puerto Rico
| Help on my mad force
I had this truck for a while and all 4 wheels just started to wobble and they shiver when running. Any ideas on how to fix it? If any body has a good idea just let me know, and some other upgrades if needed. |
03-11-2014, 06:51 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
| Re: Help on my mad force
Shivver? Are they out of balance like the foam has come apart? Or are the wheels broken or warped? I think the best improvement, from what I have read, is to stiffen the radius arms. The stock ones flex and can cause some issues. CV shafts instead of the stock dag bones too. The Sticky at the top of this page has a ton of info too.
03-15-2014, 12:04 PM | #3 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
Sound like maybe his Hub bearings are shot Regards, Rick |
03-15-2014, 03:52 PM | #4 |
| Re: Help on my mad force |
03-30-2014, 08:46 PM | #5 |
Ok were can I find that?
03-30-2014, 08:49 PM | #6 |
The tires are brand new and also got the front CVD and have them installed. After this upgrade it started to wobble the front wheel.
03-31-2014, 05:48 AM | #7 |
I also remember a thread here that upgraded the diffs to the inferno one, just can't find it.
03-31-2014, 05:51 AM | #8 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
04-09-2014, 10:35 AM | #9 |
Another thing I need cvd's on both ends, we're can I get them? The ones that I use are cvd in one end and they keep pooping out due the excessive torque.
04-10-2014, 09:38 AM | #10 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
do you mean the dog bones keep popping out? i have never heard of a cvd popping out. again supershafty.com can help you out with the CVDS... i hear he might have some new products coming along sometime in the near future too. |
04-10-2014, 03:26 PM | #11 |
04-29-2014, 09:21 AM | #12 |
RCC Addict Join Date: Jun 2006 Location: Maryland
I have this same problem with my MF VE. I dont think its the bearings, its almost like the foams are twisted inside the tires causing the whole tire to vibrate/wobble horribly. Makes the entire truck shake at speed. |
04-29-2014, 11:33 AM | #13 |
RCC Addict Join Date: Nov 2008 Location: Frederick
I'd try putting firmer foams in it.
04-29-2014, 04:09 PM | #14 |
Have you felt the tires to see if the foams actually have added up? Definitely need to fix this. Bring next time we.meet up. Ill bring mine and we can compare Sent from my KFSOWI using Tapatalk |
04-29-2014, 04:10 PM | #15 |
When my wraith has wet foams it shakes violently above 20mph.
Help on my mad force - Similar Threads | ||||
Can somebody please identify these axles as rock force or mad force? | 97sfeclipse | Kyosho Crawlers | 2 | 03-27-2010 04:59 PM |
Difference between X-factor, Twin Force and Mad Force axles | Flatty | XTM Crawler | 1 | 09-11-2008 05:48 PM |
Is the Mad Force interchangable with Twin Force part | Trac95ker | Kyosho Crawlers | 2 | 04-12-2005 12:11 AM |
