12-11-2014, 08:23 AM | #1 |
Newbie Join Date: Jan 2014 Location: Norway
| I need a diff advice.
Hi. Guys, i need a advice aboute the MF difs. I constructed quite big Monster truck, with the 1900KV brushless system, 8 inch tall rampage wheels, MF widened axles and custom made aluminium frame. The entire structure is fairly bulletproof, except the stocks diffs ( they did't lock). I was allready litle bit warry about them before first test drive. Well, i decidet to run first on Lipo 4S 6000Mah 40C. After a few minutes i blown up front one, and day after ( i was running just 2wd) rear one was give up as well. Because i want to run 6S and possibly a RC4WD demolished tires in the future, i start to search a buletproof diffs whats can holde this monster. I found a helical set - MA050 (used in stock VE i think ? ), and some steely straith one from SS. Wich of them is better , and can easly handle this power ? I know there is a tons of info on this topic, but I want to hear your opinion firs, before i will buy something. Any other suggestions aboute buletproof diffs please Last edited by Peter30; 12-11-2014 at 08:30 AM. |
12-11-2014, 09:18 AM | #2 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: I need a diff advice.
both of those gears are hardened steel and should work better than the stock gears. the stock gears are pot metal and will break with a lot of power. make sure that your diff gears are also shimmed correctly. alot of the play will allow the gear to strip more easily. i have both the hardened straight gears and the helical gears and i have never had either break on a 4s 1900 kv monster truck. |
12-11-2014, 09:36 AM | #3 | |
| Re: I need a diff advice. Quote:
One more think aboute fitting this one all togheter: Is it like, its have to be fits perfectly with zero clearance ? What lubrication should i put on it ? | |
12-11-2014, 11:57 AM | #4 |
you should put a nice think axle grease on the gears. you want the mesh to be close but not too tight that the diff case doesnt go together well. |
I need a diff advice. - Similar Threads | ||||
do you need a sealed diff to use heavy diff oil? | jebster | Newbie General | 1 | 10-10-2012 07:13 AM |
whats the Diff, between maxx 3.3 diff and revo diff? | 12voltfun | Traxxas Crawlers | 2 | 06-06-2009 09:16 PM |
AX10 Diff Locker working on Wheely King Diff | rcpaintworks | HPI Wheely King | 6 | 08-18-2007 09:13 AM |
