Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: Please double check my wiring, Fo-xx
Old 05-28-2015, 03:26 PM   #1
Default Please double check my wiring, Fo-xx
Hi,
my first post
I got my new Fo-xx VE today. It is fitted with an Orion Vortex R8 ESC.
I have bought a pair of 5,000mha 40c 3s lipo packs. The truck comes with a prewired pair of plugs that link the + and the - together on Deans conectors.
I assume that would be for twin 7.2 nicads giving 14.4 volts as the truck can be run on 4s.
So if I were to run twin 3s lipo, I'd need to make a 'Y' harness so both the + and - are joined together. this would then give the ESC 11.1v at 10,000mha.
Am I correct ????
This is what I have in my manual. I don't think it is right for twin 3s ??? Please advise
Thanks
Rob.
Foxxy is offline   Reply With Quote
Old 05-28-2015, 06:17 PM   #2
Default Re: Please double check my wiring, Fo-xx
Hi just get a deans connector the female side and short across the solder tabs and connect them across and plug it into one side of your esc's plugs the side by the #4 in the photo and then you can use the other one for 3s.
Originally Posted by Foxxy View Post
Hi,
my first post
Am I correct ????
Thanks
Rob.
shenlonco is offline   Reply With Quote
Old 11-24-2015, 07:24 AM   #3
That picture is a series diagram.. (6s with 2-3s) You want parallel wiring for double the Mah..
Tommy23490 is offline   Reply With Quote
Please double check my wiring, Fo-xx - Similar Threads
wiring crawler double check rc dreemer Electronics 9 07-01-2013 08:39 AM
Check out these's Double Pully rockn2 Chit Chat 5 06-18-2012 05:30 PM
Double Check hibbs Electronics 3 04-13-2011 06:59 PM
Double check me please!!! Veilside159 Newbie General 4 11-30-2009 09:12 PM
