02-03-2007, 06:10 PM | #21 |
Quarry Creeper Join Date: Sep 2006 Location: on the rock
Ok I got the Hot Bodies ring and pinion and I must say it has a very nice spiral cut. Not to mention the LHS guy says alot of Kyosho buggy owners is using this HB ring and pinion. Which you could find more often than Kyosho ring and pinion. Oh yeah diff. outdrives is much more beefier and everthing bolts up nice and rotates way more smoothly than stock ring and pinion. http://www2.towerhobbies.com/cgi-bin...1p?&I=LXJBM4&P http://www2.towerhobbies.com/cgi-bin...1p?&I=LXJBM3&P Last edited by pureadrenalin; 02-03-2007 at 08:52 PM. |
02-05-2007, 07:43 AM | #22 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
| Huge Find
This is an Ofna Torsen Diff (torque sensing) It dose work in our Twins. Found at Tower http://www2.towerhobbies.com/cgi-bin...&I=LXMVX9&P=PU Oh and these sure look familiar http://www2.towerhobbies.com/cgi-bin...?&I=LXEPA9&P=M Last edited by Bart bender; 02-05-2007 at 08:40 AM. |
02-05-2007, 10:35 AM | #23 |
And with RCP having a SUPER deal on Twin axles kits (wide or narrow options)Twins can be built easily. |
02-05-2007, 01:31 PM | #24 |
| Update 1 !!! Here's a list of HB parts that work. Both Tower/HB part#'s 43T Helical ring gear #LXJBM4/C9010 10T Helical pinion #LXJBM3/C9009 Steel bevel & spider gears #LXEPA8/C8101 Hardened steel "" #LXLGV5/C8101-1 Right/Left Knuckle #LXEPA9/C8081 King pins #LXJBE7/C8063 Rubber sealed 8x16mm bearings(4) #LXJBE2/C8020-1 And some OFNA parts. Tower/OFNA part # Torsen Diff #LXMVX9/10596 NEW gear set OFNA# 40626 12T pinion (Hyper 7) #LXCVT8/19028 43T ring gear (Hyper 7) #LXCVR1/19001 13T pinion (Jammin) #LXLMX1/40516 43T ring gear (Jammin) #LXLMX2/40517 Knuckle (Hyper 7) #LXCVU2/19032 CNC Knuckle (Hyper 7) #LXCWA8/19304 Knuckle (Jammin X-1CR) #LXLLE4/40520 Rubber sealed 8x16mm bearings (2) #LXBZP0/36053 Stainles king pin set (Hyper 7) #LXCWA4/19232 Not sure but these measure VERY close to both Twin axle shafts they measure 104mm & 93mm long Center Swing shafts (Hyper 7) #LXCVX7/19067 Here are some VERY beefy ball ends for links 6-7mm balls #LXCWJ4/36850 6-7mm ball end #LXCWH9/36690 Last edited by Bart bender; 03-16-2008 at 02:27 PM. Reason: Add #'s |
02-26-2007, 03:24 PM | #25 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
Check this out http://ofna.com/newproducts.php I checked and Tower does not have the gears in stock yet Edit: Stormer has the X1-CR gears. Supposedly they fit the 777 buggies and are spiral cut. https://www.ssl-stormerhobbies.com/c...ns&pn=OFN40626 Last edited by ThinkTank; 03-01-2008 at 11:36 PM. Reason: New Info |
02-26-2007, 05:31 PM | #26 | |
03-08-2007, 05:33 PM | #27 | |
Newbie Join Date: Apr 2006 Location: Genova, Italy
03-08-2007, 09:23 PM | #28 | |
03-09-2007, 06:25 AM | #29 |
They are like the Detroit Truetrac.
03-11-2007, 06:36 PM | #30 |
No, no... they are real TorSen... see http://ofna.com/pdf/Torsen-Diff-F&R.pdf... |
03-11-2007, 08:01 PM | #31 | |
03-12-2007, 10:14 AM | #32 |
Newbie Join Date: Dec 2006 Location: Ravenna
They work just like a real Torsen or Detroit true-track. Good for regular trail use but will not lock up if 1 tire is off the ground. On a real rig you can make it work by applying brake pressure to trick the diff into "thinking" it has some traction at the wheel that is hanging in the air but that can't be done on an Rc crawler. I had the True-Track in my real Jeep's front axle. Waaay better than an open diff but not a replacement for a locker. It just depends on what you are using it for. This being a crawler forum I would be willing to bet that most of us need the locked axles. I plan on building a 4 link Twin for general bashing and the torsen diffs would work great but if I choose to crawl with it RC Alloy spools will go front and rear.
03-12-2007, 10:35 AM | #33 | |
If I was building a truck for the track or just bashing around the yard,maybe they'd work great for that. Still be hard to cough up that much dough though,a tube of 500,000 weight diff oil will do simular | |
03-13-2007, 06:40 PM | #34 | |
03-13-2007, 07:10 PM | #35 |
First question: BS19 are stock hubs on TwinForce and BS76 are stock hubs in MadForce... which is the difference?? Second question: IF6B are stock hubs of Inferno (ST-R and MP777), but has anyone tested them on Twin/Mad axles? Thanks in advance! :-P |
03-13-2007, 07:59 PM | #36 |
Some buggy hubs have caster built into them,gotta be careful about that part. I've got some buggy hubs here that will bolt up fine,same bearings and everything.....they've just got caster built in. The difference between the Mad/Twin hubs...I'm not sure exactlly what the difference is but I know they will bolt up fine. I've run Twin and Mad Force hub carriers with no issues. If I was to guess at the difference,it would probably be in the arms where the steering linkage bolts up |
03-14-2007, 06:42 AM | #37 | |
If I had some connections, psst jason, I would get some and test them to make this a 100% yes answer. | |
03-14-2007, 11:20 AM | #38 | |
03-16-2007, 02:08 AM | #39 |
Newbie Join Date: Jan 2006 Location: Reno 911
Did you try turning the knuckles so they face the opposite direction on different sides. This usually increases the turning quite a bit. It was also required to cut a notch through the middle of the shock mounting area for the knuckles to clear easier (will give more clearance for turning). On a different subject, my stock ring and pinion has lasted over a year. Anyway, the reason I was looking on here was to figure out what axle shafs I could use for the short side. I tried a rc10gt dogbone (too small), I also tried a raze dogbone (right size, but a little to long, I'll have to return it), then I tried an XTM Xterminator buggy short side.......voilla a perfect fit. The moral of the story: Check what you have in your toolbox before trying the hobby shop!! Especially if you have an 8th scal buggy as well. I'm pretty sure the extra r/p for the buggy will work in the twin crawler. What are you guys doing with the CA glue? I used JB Weld in the diff a year ago and worked fine. |
03-17-2007, 10:46 PM | #40 | ||
Mine are still in the factory configuration with uncut steering stops. I bet I can turn sharper:-P Quote:
CA glue.....diff lock. Same theory as JB Weld but cheaper:-P | ||
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/kyosho-crawlers/58270-%2A%2A%2A-twin-force-upgrades-%2A%2A%2A.html | ||||
kyosho madforce kruiser ve - Monster Trucks @ URC Forums | This thread | Refback | 02-22-2013 06:29 AM |
