| | #1 |
| Newbie Join Date: Feb 2005 Location: PHOENIX
| i wanted to know if 100,000 wt diff oil is enough to lock the diff in my twin force or will it just give like it does now |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Jun 2004 Location: FLORIDA
| it wont lock it like your wanting it to, it will only slow the action down not stop it. after a while it will loosten up so you'd be better off either jb welding those diffs OR getting a locker similar to those for the savage gear cases as ive ben told the diffs are similar |
| | #3 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| The best you'll get with fluid in the diffs is,at best,a limited slip. Even then 100,000 weight won't do anything. For the best "limited slip" performance you NEED to run 300,000 weight cuz,like said eairlier,it'll loosen up over time and become thinner. If you want true locked up performance,weld it up or buy a spool. Look up RC Alloy's,they help support the site and build some clean stuff,including spools for the Twin |
| | #4 |
| Pebble Pounder Join Date: Sep 2004 Location: Phoenix
| Come on Nick, jb weld that thing up man! |
| | #5 |
| Newbie Join Date: Jan 2005 Location: Flagstaff AZ
| no matter what oil you use its not doing what you want, lock it any way you can but dont try any oil, waist of time and money. |
| | #6 |
| he has locked it with jb weld and its working great |
| Thread Tools | |
| Display Modes | |
