Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Long travel shock options
Old 09-12-2010, 02:15 PM   #1
Default Long travel shock options
Apart from the HPI Baja rears which are 207mm extended, are there any other options for long travel coil over shocks out there suitable for a 1:5 scale beast?
As usual, the cheaper the better!
Thanks,
Bish.
Bishbosh is offline   Reply With Quote
Old 09-15-2010, 03:04 PM   #2
The only other long shocks are the hpi savage, and they are a little small for a 1/6 imo. I have the baja shocks on my 1/6 campbell and the springs are way too stiff. And thats with a 7lb bare chassis on top of em. I can't seem to find any soft springs for them.
supercrawlerfreak is offline   Reply With Quote
Old 09-15-2010, 10:46 PM   #3
Found some. Damn, I wish I looked here before I got my set. http://cgi.ebay.com/HPI-Baja-5B-5T-A...item45f2a51adf
Pangasinan is offline   Reply With Quote
Old 09-16-2010, 12:59 PM   #4
Thanks folks.
Looks like I had better keep my eye on eblag then!
Old 09-17-2010, 12:13 PM   #5
Well, would you believe it!
No sooner had I made my last post than I found a complete set of Baja shocks with a starting price of £25.......
This evening they belong to me for the princely sum of £27.34 .
They are advertised as used, but at that price I can't really go wrong!
Now to go and learn how to remove purple anodising!
Old 09-20-2010, 10:41 AM   #6
To remove the anodizing, break the shocks down and soak them in a pruduct
Called Greased Lightning. It takes it off pretty well without using drain cleaner.
mr.freeze is offline   Reply With Quote
Old 09-23-2010, 10:17 PM   #7
I'm running the same set up on my 1/6 scale rock racer. I am using the yellow soft hpi springs front and rear. and they are way way too stiff. So I went to the hardware store and found the stiffest spring I could that fit inside the shock body. I lost about 1/4'' of travel overall, but it was worth it to make them softer. At such a large scale, savage shocks just look wrong.
best of luck too you on finding springs, i feel your pain.
irok22s is offline   Reply With Quote
