04-26-2012, 04:03 PM | #41 |
Quarry Creeper Join Date: Sep 2010 Location: where ever I layed my hat.
| Re: Certainly not original "Willys"
I measure twice and cut once. I measure three times, think about it for many many minutes, measure it again and finally bend once. I am pretty sure it was beginners luck. |
04-27-2012, 09:47 AM | #42 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
Very nice build so far!
06-03-2012, 12:10 PM | #43 |
Here is a little progress. A piece of aluminum. A frame rail pattern. A couple of rails scratched into the plate ready for cutting. Maybe some day this thing will be a crawler. |
06-15-2012, 04:14 PM | #44 |
Finally broke out the almost not adequate scroll saw. Even though this is not the most ideal way to do this or the best work area I was able to prevail and we have a pair of frame rails waiting for file/ dremel/ sanding work. The cross members should not be as much of an effort. |
08-04-2012, 06:38 PM | #45 |
Rock Crawler Join Date: Feb 2012 Location: NORTH SYRACUSE N.Y.
kinda strange your building a willys and your aluminum says kaiser , cool build
08-09-2012, 07:40 PM | #46 |
| Re: Certainly not original "Willys" |
08-10-2012, 06:52 AM | #47 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Re: Certainly not original "Willys" Quote:
I've thought about buying a scroll saw but was always afraid I'd "overwork" it once I had it. I may think about it again now... | |
08-13-2012, 12:37 PM | #48 |
Pebble Pounder Join Date: Feb 2009 Location: Augusta
The major problem I've had cutting frame rails using a scroll saw very similar to this one is that there are really no proper blades available for the task. The last set I cut must've cost me 6 blades. Nice looking work there, man. |
08-13-2012, 08:02 PM | #49 | ||
Almost done with another hobby/ project. A buddy built this frame (I have dreamed about having one for 20yrs now) and I finally got my hands on it. It's a 26" sort of trials bike with a rear derailer, also dubbed Strange Bike #12. Chris King hubs/ headset, Magura hydralic brakes and various other bits and pieces have been taking away from the Willys. Hope to be settled and have my tools available to me again by the end of the year so I can get back to this Willys project. Last edited by snydercj7; 08-13-2012 at 08:05 PM. | ||
09-08-2012, 07:43 PM | #50 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
Hoping this Willy's hasn't thrown in the towel it has a great start to it |
12-31-2012, 09:57 AM | #51 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
You do any more work on this Willys?
12-31-2012, 01:00 PM | #52 |
Not to worry, finally settled in on the other side of the country and pulled my little sander and drill press out of storage. I have cleaned up the main rails as well as cut out and cleaned up cross members and bumpers. Figured once I have them drilled, tapped, and frame mounted to the body I would give an actual update.
01-18-2013, 01:34 PM | #53 |
For those that have had an interest in this slow to build thread. Getting the drill press & sander out of storage, adding a tap & die set to my collection, I finally can present you all with a basic frame. lol At this rate I might finish my Willys by retirement, which is a very long ways away. A peak at the under carriage. A couple of front shots. Next step will be to get the body holes drilled into the frame so I can get my 4 link triangulated suspension tide into the mix. Starting to get excited to have this thing actually sitting on it's own vs with jack stands. A quick mock up. Last edited by snydercj7; 01-18-2013 at 02:27 PM. |
01-18-2013, 05:14 PM | #54 |
| Re: Certainly not original "Willys" It's good to see this one being worked on again!! Too nice a start to give up on!
01-22-2013, 04:25 PM | #55 |
Now that I am getting closer to installing the drive train. Any one have any experience with the RC4WD planetary transmission. Wondering how it will actually hold up to a possible 20lbs and power needed to get this beast rolling over technical trails. Every one swears on the Axial trans wondering if that would also be a better way to go and get me out of the 115:1 crawl ratio. After getting my the planetary transmission I was more then disappointed to see the thin stamped gears which have pushed my concern.
01-22-2013, 07:56 PM | #56 | |
Rock Crawler Join Date: Nov 2006 Location: Holland
The planetary transmission can handle the torque but it is heavy and quite long with a motor bolted to it. If you decide to go with the planetary transmission make sure to break it in first (no load) with a big blob of grease. This will make it a lot less noisy. | |
01-23-2013, 05:00 PM | #57 |
Any one know the actual ratio for the Axial transmission? I know you can very it with the spur and pinion. I am looking at a 16:1 ratio on the planetary. Good to know that the planetary can handle the torque. Would like to get this thing set up correctly with a motor that will not be screaming to make this pig move at more then a snails pace. Probably need to connect with Mr. Holmes to narrow down this decision.
01-23-2013, 06:36 PM | #58 |
Another question for the Willy's crowd. What is your frame height, wondering where the group is sitting? I don't want to make this thing sit up too high, but would like some decent break over. |
01-24-2013, 03:30 PM | #59 | |
01-24-2013, 06:38 PM | #60 |
Thanks for the info BigSki. My current drive train ratio 115.45:1, the ratio from above would have me @ 102.03:1. Not a huge difference, I dont think. Guess I will try what I have.
